obd1 vss ecu wiring
Old Feb 26, 2013 | 11:59 AM
myefhasaname's Avatar
Default obd1 vss ecu wiring
Im working on hooking up the vss to the ecu to get rid of my cel 17. Connecter b pin 10 i have as the pin into my ecu, but where does that wire go after the fire wall?
Old Feb 27, 2013 | 08:45 PM
Default Re: obd1 vss ecu wiring
well if anyone is having the same issue i have found that on the ef cluster harness a yellow and red wire (b2) is the wire that goes back to the vss
00IntegraR
Nov 29, 2011 08:54 AM
hatchyboy89
Feb 2, 2006 06:00 AM
Pimpstecy
Jun 23, 2003 09:57 AM
Pimpstecy
Jun 4, 2003 04:43 PM
