lsvtec conversion??????
Hey dude just google it you will find a ton of help this has been covered thousands of times which is why no one will take the time to answer your question. If you bought a "real" conversion kit then it should have come with the line.
you stick the thing in that thingy and run the lines from the thing to the thingy.. put head on run vtec go WOOOOOOT.. done.
http://www.lightningmotorsports.info/tech_lsvtec.htm
http://www.modified.com/tech/0411scc_ls_vtech_engine/
