FS/FT: 1991 SILVER CRX Si w/ B18C5*JDM SiR converted w/ GLASSTOP!!*
Old Feb 25, 2013 | 06:34 PM
88crxsir's Avatar
Default FS/FT: 1991 SILVER CRX Si w/ B18C5*JDM SiR converted w/ GLASSTOP!!*
Ok im sure i'll get plenty of "NO DON'T DO IT!" reply comments, but 13 years is enough!!! i can't keep this car anymore!! i have NO TIME, NO USE, NO DESIRE to keep a show status car that serves only that purpose. this car has been built beyond a daily cruiser considering i shaved & deleted wipers & defroster. i do somewhat regret that i have to sell it cuz i always feel it's never too late to bring it back, BUT w/ my wife not working, a new baby girl, me working all the time. Basically my everyday life is priority & i just can't find the time or motivation to keep it. i currently own 6 vehicles & it's become a hassle more than anything & w/ everything going on in my life right now im feeling like i need a break from anything car related!! The car scene has been the only thing i have focused on for so long that i put everything else that matters on the side & it's time for a change!!! SO IM STARTING HERE NOW!
**********WILLING TO SELL MOTOR & ROLLING SHELL IF I GET A BUYER FOR BOTH & WILL CONSIDER REASONABLE OFFERS & TRADES********************
HERE IT IS!
1988 honda crx si converted to 1991 jdm sir (NOT RHD) obvisiously!!
*CLEAN TITLE*
NH-95M BLADE SILVER
Car has ALL BRAND NEW OEM HONDA MOLDINGS, SIDE SKIRTS, DOOR CAPS, FENDER CAPS, BUMPERS, SIDEMARKERS, & BUMPER LIGHTS!!
CLEAN PAINT JOB & HAS BEEN GARAGE COVERED FOR 100% OF IT'S LIFE SINCE I'VE OWNED IT!
I have alot of paperwork on this car & it's parts. honestly i have restored this car about as good as you can get w/ complete jdm sir exterior/interior.
100% COMPLETELY NEW FRONT SUSPENSION including every single bolt!!!!!
100% COMPLETELY NEW BUILT MOTOR including every single bolt!!!!!!
HUGE PARTS LIST WHICH I WILL POST UP ASAP!!!
I WILL ALSO POST UP CURRENT PICS AS WELL!!
car is just a bit dusty & just needs a wash which i will do soon.
now to the PRO's & CON's!
PRO's :
honestly who ever buys this is getting a hell of a deal!! i put dam near $28k into this car over 13 years & for the price im letting it go for is MORE than fair!!! it's CHEAP!!!
************************* EDIT UPDATE *************************
*****CAR WILL COME W/ SILVER KOSEI's***********
-NEW PARTS ADDED TO THE CAR
-OG Skunk2 ITR manifold
-SK2 black composite fuel rail
-SK2 alpha 70mm TB
-NEW fully polished OEM 270cc inj
-NEW TD88U Dizzy
-NEW RYWIRE dist jumper
-NEW Bosh wires
-NEW ITR Throttle cable
-black chaulk PC valve cover
-NEW Comptech Int w/ CARB # badge
-BLOX TRI-Y header
-NEW ITR Throttle cable bracket
-NEW v.2 downstar dress up beauty washers
Chipped 0bd1 ecu w/ SK2 ITR program
THE ONLY PARTS THE CAR DON'T HAVE ANYMORE ARE THE WHEELS, SPOON CLUSTER, ITB'S, SMSP HEADER, AEM SETUP.
PRICE: $11k COMPLETE OR $8K COMPLETE SHELL OR ILL PART OUT *DON'T BE SHY, HIT ME UP!!!
Propulsion
B18C5
Polished HaSport engine mounts
Blox B Stage 2 camshaft
Port and polished cylinder head
3-angle valve job
Blox flat valves
Supertech valvesprings
Supertech valve retainers
Block bored/honed .25 over
.25-over B16 pistons
High-flow catalytic converter
Rywire inside-cabin fuel line tuck
Earl’s black anodized -AN fuel fittings
Earl’s black braided fuel hoses
Trick Flow fuel filter
AEM fuel pressure regulator
Rywire custom fuel hard line
Rywire mils spec engine harness
NGK iridium spark plugs
Mizu full-size radiator
S1 cable transmission
Polyurethane shifter bushings
ACT 6-puck spring clutch
ACT heavy-duty pressure plate
Fidanza flywheel
CTR Helical limited-slip differential
Integra GS-R midshaft
Suspension
D2 Racing 36-way coilovers
Suspension Techniques front sway bar
Suspension Techniques rear sway bar
Polyurethane suspension bushings
ASR subframe brace
Innovative traction bar
Function7 lower control arms
Completely overhauled suspension with new OEM components
Resistance
Wilwood 11-inch 2-piece front brake rotors
Wilwood front brake pads
Wilwood Dynalite 4-piston brake calipers
Wilwood brake lines
Wilwood 5/8-inch brake master cylinder with brake booster delete setup
QSD delete plate
Rywire custom stainless steel brake hard line
Rywire custom in-cabin brake line tuck
Fastbrakes 11-inch rear brake conversion kit
Exterior
Shaved engine bay
CRX SiR glass top
J’s Racing front lip
JDM CRX SiR front end conversion with supports
Clear EF/DA side markers
Interior
Recaro Pole Position seats
Complete JDM CRX SiR interior
JDM Gathers double DIN head unit
Honda Access “Honda Super Sound” speaker grilles
Vertex 330mm 10th Anniversary steering wheel
Skunk2 shift ****
Skunk2 short shifter
Custom kill switch
Relocated battery
Custom carbon-fiber climate control delete
Custom carbon-fiber shift gate
CURRENT PIC AS OF TODAY!! EXTERIORWISE it's the same, probably end up putting the foglights back on too! i'll post more pics when i get it back & wash it!
PICS: WILL POST ALOT MORE PICS:
Old Feb 25, 2013 | 07:14 PM
da9blk1's Avatar
Default Re: FS/FT: 1991 SILVER CRX Si w/ B18C5*JDM SiR converted w/ GLASSTOP!!*
Yum
Old Feb 25, 2013 | 08:45 PM
88crxsir's Avatar
Thanks
Old Feb 26, 2013 | 11:28 AM
88crxsir's Avatar
Bumps
Old Mar 3, 2013 | 10:43 AM
88crxsir's Avatar
NEW PRICE UPDATE!!!!!
TAKE A LOOK!!!!!!
Old Mar 3, 2013 | 08:30 PM
88crxsir's Avatar
Bump ttt
Old Mar 5, 2013 | 03:15 PM
gotkimchi's Avatar
I will throw in an offer. $8k cash for the complete car or $6k cash and 95 integra GSR.
Otherwise bump for the cleanest CRX I have ever seen.
Old Mar 5, 2013 | 03:29 PM
EVIL EF9 RHD's Avatar
Bump
Old Mar 5, 2013 | 03:42 PM
88crxsir's Avatar
Thanks
Old Mar 6, 2013 | 12:01 AM
88crxsir's Avatar
bump ttt
Old Mar 7, 2013 | 12:05 AM
88crxsir's Avatar
Up for the night
Old Mar 7, 2013 | 01:00 PM
gotkimchi's Avatar
so fresh and so clean clean!
Old Mar 7, 2013 | 02:51 PM
88crxsir's Avatar
Bump
Old Mar 10, 2013 | 11:36 AM
88crxsir's Avatar
Bump ttt
Old Mar 10, 2013 | 06:48 PM
kingofbattle909's Avatar
Old Mar 21, 2013 | 10:56 AM
ttttt
roadhead
Texas -OK -LA (Sales)
Apr 10, 2013 04:11 PM
applecore
Feb 7, 2008 06:00 PM
Talonryda17
Northeast (Sales)
Mar 24, 2007 12:16 PM
racer-025
Canada (Sales)
Sep 19, 2005 05:33 PM
Mr.SpiLLz
Jun 19, 2003 03:54 PM
