The end of all swap questions thread!!
Surje.motorsports
There seems to be a large amount of people with swap questions...this is the thread you will post in if you have questions, i will also be compiling a number of threads that i have used and that provide great information for those looking to swap, you will also find most of the answers to the questions you are asking in the links i post...if you ask a question that has already been answered in one of the threads that i post a link for; I, or one of the other mods will point you towards the right direction. DO NOT MAKE THREADS REGARDING SWAPS FROM HERE ON OUT!!
Surje.motorsports
k-series engine info(find your motor):
http://www.ephatch.com/forum/showthr...ne-Information
k20a2 into ep3:
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/everything-you-need-swap-k20a2-into-ep3-2410236/
Intake Manifolds:
RBC Manifold:
http://forums.clubep3.com/showthread.php?t=564540
http://forums.clubep3.com/showthread.php?t=832679
PRB vs. PRC
https://honda-tech.com/forums/k-series-153/prb-vs-prc-same-different-2755423/ .this is really old.
best breakdown of manifolds on the market that i could find...Shows HP gains with dyno sheets and supporting mods and software used for the tunes
http://www.superstreetonline.com/tec...t/viewall.html
k20a2/z1 oil pump conversion for a2/z1/z3///k24a1/etc:
http://forums.clubep3.com/showthread.php?t=838200
k20z3 oil pump info,
http://www.k20a.org/forum/showthread.php?t=42496
oil cooler conversion:
what you will need,
JOINT, OIL COOLER (s2000)
11107-PT2-000
k20a2/z1 oil cooler
k20a2/z1 water pump...
http://www.k20a.org/forum/showthread.php?t=81339
http://www.k20a.org/forum/showthread.php?t=34850
common k24 questions answered:
http://www.ephatch.com/forum/showthr...tions-answered
k20a2 into ep3:
Intake Manifolds:
RBC Manifold:
PRB vs. PRC
what you will need,
11107-PT2-000
k20a2/z1 oil cooler
Hey nahonda04 i don't see this question answered it's about a k20z3. Mine has 140k on it and was looking to swap a k20s fd2 in it but was told i should just rebuild my current motor. What do you think? Sorry if that's a noob question here im new to honda tech...
Surje.motorsports
there may be, k24 would be the most common but you wont find it in this section of the forum, this thread is designed for people that already have k's and are looking for rebuild methods or ways to improve their current setup, i.e. k24's, built motors, swappable parts between chassis, etc...
rebuild would be easiest and most cost effective rather than buying a whole new motor
