2001 Civic -- cylinder misfires
pull the coil packs out and see if there is oil on them. if not, pull the spark plugs and check for the same thing. if so, you might need to change out the valve cover gasket as well as the spark plug seal. Also, you might want to change out the spark plugs as well, just to do a thorough job.
ShaneDur
Engine Management and Tuning
Nov 2, 2015 02:04 PM
