OBD1 SOHC ZC in a 93 civic dx
Old Feb 25, 2013 | 09:21 AM
A.VGCSRT8's Avatar
Default OBD1 SOHC ZC in a 93 civic dx
Hey guys new here been searching using google and can't seem to find an exact yes or no answer. I have a 93 civic dx I use for a commuter car because my Jeep is not a good commuter since it runs on 91 oct and gets 18 mpgs hwy. Anyway I swapped in a obd1 sohc non vtec zc motor about a year ago and it runs great but my timing is a couple degrees off/ below what it should be and my stock td41u dx distributor is fully advanced, is there another obd1 distributer I should use or is the timing problem somewhere else?
Old Feb 25, 2013 | 09:36 AM
CCoady26's Avatar
Default Re: OBD1 SOHC ZC in a 93 civic dx
Your timing belt could be off a tooth
dI'd check there before I looked into distributors.
Old Feb 26, 2013 | 03:36 AM
slowDB7's Avatar
if its off by a couple degrees, then you should reset your timing
acmoc
Jan 9, 2012 08:45 AM
migizzel
Nov 14, 2005 10:10 AM
sLoWrAcEr
Jun 22, 2005 10:17 AM
articbluedc5
Aug 20, 2004 09:44 PM
btcca4
Jul 1, 2004 09:03 AM
