k20z1 and a2 trans into 02 ep3
Old Feb 24, 2013 | 10:15 AM
b_boy_numero_3's Avatar
Default k20z1 and a2 trans into 02 ep3
I have an 02 civic SiR (canadian) and was planning on doing a k20a2 swap, with the six speed. I found a motor, tranny, and wiring harness from a junk yard out of an 03 rsx-s. But when I picked it up and checked the stamp on the block, its a z1, so it must have been previously swapped. I did some more research before I left with it, and got the guy to knock a few hundred off the price because I might need a few parts. When I got home, I checked the tranny code, and it is an a2 tranny, so I shouldnt have any vss issue. I am going to k pro my computer (don't care about reverse lockout), and I dont see any modification to the wire harness, so I assume its from the car, not the motor. I am going to attempt next week to plug my ecu in, just to see if the plugs are the same, that's the only way I can think of to be sure its an 02-04 harness.
Now, my questions are this. Is there anything else that is different with swapping a z1 in, rather than an a2 ? I did months worth of research before hand, and now, and it looked like it was only the tranny issues, and the newer wire harness for k pro. But if I'm right, I wont need to worry about those.
Also, playing around with k-manager, and there are only 2 base maps for the z1, one labeled for the 2005, and one for the 2006. I was wondering how they differ, because at a quick glance I can see the vtec windows are quite different. I didnt think there was any different from 05 to 06. Also, I'm not sure what year the engine is from, is there any way to tell ?
Any help would be greatly appreciated.
Old Feb 25, 2013 | 05:56 AM
turbohatchBnuts's Avatar
Default Re: k20z1 and a2 trans into 02 ep3
When you do your swap use your ep3 engine harness, everything will plug in. The knock sensor on the z1 block is different then the orginally knock sensor wiring on the ep3 harness. Just use the knock sensor off your a3 block. As for the kpro your going to have to use a kal setting for the ecu you kpro. prb = prb kal settings , or pnf = pnf kal setting, etc. For the tranny your just not gonna have reverse lockout. The cylinder head has the year it was made on it, usuallay a circle stamping.
Old Feb 25, 2013 | 06:31 AM
I have to use a pnf base map ? Those are for an a3, so obviously it won't run a z1 properly. Do I have to basically copy and paste all the values over ? I don't plan on getting it tuned for a bit
Old Feb 25, 2013 | 09:35 AM
the prb settings may work on the pnf ecu. I loaded an 04-05 tsx dual adapter kal on my prb ecu and my temp gauge qwit working. So I would image the prb kals would work ,but may be missing some pins for its wiring harness.
Old Feb 25, 2013 | 10:38 AM
Oh, okay. Does anybody have any insight that has used a pnf on an a2 or z1 ?
Old Feb 25, 2013 | 07:04 PM
If you have kpro then your probably getting it dyno tuned right? Ask your tuner. Or for the time being just upload a prb kal. See if anything isnt working right afterwards.
Old Feb 26, 2013 | 08:55 AM
I am going to get it tuned, but not for awhile yet, untill I figure out what mods I want to do, turbo or just some lighter stuff. I'm a 19 year old apprentice mechanic, so money is exactly plentiful
Old Feb 26, 2013 | 11:38 AM
Save up and get cams , valvetrain , and a good header. Then go get it tuned. For now just use the prb kal settings that match what you have.
Old Feb 26, 2013 | 12:04 PM
What brands do you suggest ?
Old Feb 26, 2013 | 05:42 PM
drag cartel endurance camshafts or the stage 4's or if you can find them ips k2's. Supertech valvetrain. Toda race header.
Old Feb 27, 2013 | 12:08 PM
Does anybody know if I can use my a3 alternator ? Because the z1 didn't come with one
Old Feb 27, 2013 | 05:21 PM
Your gonna what to use all the accessories from the k20a3. Alternator, tensioner, ac , crank pulley, etc.
Old Feb 28, 2013 | 06:47 AM
Thanks man, you're been a huge help. just looking into all my options, does anybody know which kit I would go with if I wanted to do a jackson racing supercharger ?
Old Mar 1, 2013 | 03:56 PM
I would get the one that matches the motor. Like the Rsx type S kit.
Old Mar 3, 2013 | 06:10 PM
well, started working on the z1 on the ground today, and a couple new developments. It is a z1 block, a2 trans, prb intake manifold. WTF ?! Also, turbohatchBnuts, the only stamping on the head I can find, are 10 digits, and if they are the last 10 of a vin, then the head is from an 03. BUT, a different 03 than the tranny is from, because it has an entire vin on it.
94_ls
10
Apr 19, 2010 02:15 PM
turbointegra94
Southeast (Sales)
Jan 13, 2008 10:40 AM
evolution_sfv
Feb 8, 2005 12:32 PM
-RedneckDave-
Feb 7, 2004 12:22 AM
