1994 Accord EX CD5 OEM Hoses/Gaskets Factory Sealed
Recently got rid of the 1994 Accord and have the following factory sealed OEM hoses and engine gaskets that need to be sold:
79721-SV4-000 Hose A, Water Inlet List: $19.40
79722-SV4-000 Hose B, Water Inlet List: $6.97
79725-SV4-000 Hose, Water Outlet List: $11.22
19104-P0A-000 Hose, Overflow List: $2.00
19501-P0A-000 Hose, Water (Upper) List: $15.72
19502-P0A-901 Hose, Water (Lower) List: $25.30
25213-PT0-603 Hose, Oil Cooler (140MM) (BS) List: $14.58
25214-P0A-003 Hose (290MM) (ATF) List: $23.60
25215-P0A-003 Hose (290MM) (ATF) List: $26.23
36455-PT3-A01 Gasket, Electronic Air Control Valve (Denso) List: $2.50
19301-PAA-306 (19301-P08-316) Thermostat Assy. (Nippon Thermostat) List: $21.98
37750-PH2-014 Thermo Unit (Denso) List: $33.77
91312-P0A-000 Gasket, Thermostat Case List: $2.50
91314-PH7-003 O-ring (31.2x4.1) (NOK) List: $2.10
19305-PT0-000 Rubber, Thermostat Mounting List: $3.63
15825-P0A-015 Filter Assy. Spool Valve List: $11.02
90471-PX4-000 Washer, Drain Plug (18MM) List: $2.20
Diagrams of items can be viewed at Majestic Honda (hondaautomotiveparts.com) where these were purchased.
If interested let me know and I will post all items on eBay (grouped together). Pictures will also be provided when listed.
Items will be sold all together or trashed all together, so no price is too low.
kevinhughes13
May 10, 2014 12:28 AM
faran
May 21, 2010 05:10 AM
