98 civic motor swap questions
Old Feb 23, 2013 | 01:59 PM
greenman94's Avatar
Default 98 civic motor swap questions
Hey guys,
I just recently picked up a 98 civic dx, 5speed with a d16y7 in it and a huge rod knock!
This morning I went and picked up another d16y7 with a y8 mini me swap. I also have the computer for the y8 head.
My problem is, the iacv is missing on the y8 head. I dont really have access to another iacv for the head right now either.
Can I use the y7 intake manifold and throttle body on the y8 head? If so, should i be using my stock ecu or the y8 ecu? I'm a little confused about what i should do or how that works?
I have two complete engines, what can i do to be able to hook up vtec and use what i have and have everything working?
Old Feb 23, 2013 | 02:04 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 98 civic motor swap questions
You'll have to use your y7 ecu with they y7 IACV.
Old Feb 23, 2013 | 02:08 PM
greenman94's Avatar
Yeah, thats what i was thinking. I should still be able to wire in vtec right?
Old Feb 23, 2013 | 02:14 PM
Technical Hero
You can wire it on but it won't activate without using the y8 ecu
greenman94's Avatar
Otherwise, if i get the iacv for the y8 head, i should be able to run that if i switch my y7 ecu with the y8 ecu?
Old Feb 23, 2013 | 02:17 PM
Technical Hero
Yeah just get an IACV. You'll have to rewire the IACV at the sensor and at the ecu, wire in vtec, wire in knock sensor.
Old Feb 23, 2013 | 02:20 PM
greenman94's Avatar
So, I need the y8 ecu to run vtec? And to run the y8 ecu I need the y8 intake and iacv? Sounds like I am better off finding an iacv for my y8 intake and going that route.
Sorry about all of the questions, I'm just trying to get this right so everything is working properly!
Old Feb 23, 2013 | 02:29 PM
Technical Hero
Yeah you'll have to run the P2P ecu for vtec and also the y8 IACV with the P2P.
Old Feb 23, 2013 | 02:31 PM
Technical Hero
nother note is that if you're gonna run the y8 exhaust manifold you'll have to get a cat welded in and extend your secondary 02.
Old Feb 23, 2013 | 02:34 PM
greenman94's Avatar
I'll be running a header on the engine. Is that going to affect where my o2 sensors will go? i dont plan on using a cat.
Old Feb 23, 2013 | 03:04 PM
Technical Hero
You're gonna throw an engine light without a cat.
Preluda1992
Aug 11, 2018 12:05 AM
Ekevans08
Dec 12, 2012 06:11 AM
vince819
Apr 4, 2012 07:22 AM
SOHC_civic_si
May 4, 2008 08:50 PM
