help with v6 caliper & rotor upgrade...
Old Oct 21, 2002 | 02:06 PM
Project SSAP1's Avatar
Default help with v6 caliper & rotor upgrade...
ok..so i just got my v6 calipers today...im still wating for my brembo rotors & axxis pads...well my question is what should i use to clean the calipers...is simple green a good solution to clean them??? what would u guys suggest???
damnit i need a digi cam bad so i can take some pics....i think ima gonna ask my girlfriend for a the sony cybershot DSC p51 or 71..lol...
[Modified by Hybrid Accord, 6:10 PM 10/21/2002]
Old Oct 21, 2002 | 03:54 PM
Default Re: help with v6 caliper & rotor upgrade... (Hybrid Accord)
can anybody help or what????????
Old Oct 21, 2002 | 04:09 PM
RotaryBzzz's Avatar
i think you want to be careful with anything not meant explicitly for brakes. I'd imagine the seals in the caliper housings would be sensitive to corossive chemicals. Stick to a good break cleaner although I'm no expert. I'm assuming you want to paint them?
Old Oct 21, 2002 | 04:12 PM
Gennady's Avatar
New User
Default Re: help with v6 caliper & rotor upgrade... (RotaryBzzz)
Use that brake cleaner spray that is meant to keep you from inhaling brake dust.
Old Oct 21, 2002 | 04:31 PM
yeah i want to clean them then paint them red....i guess ill go search for a caliper cleaner or something
Old Oct 21, 2002 | 04:39 PM
Gennady's Avatar
New User
If you want to paint them, you will have to dremel and sand them.
Dont paint them dude, painted calipers look silly.
Old Oct 22, 2002 | 04:28 AM
Stew Pidasso's Avatar
To prep them for paint, spray them down with brake cleaner (to remove the brake dust). Then get a wire brush and rub the **** out of them. An easier alternative would be to use a brass or steel wire wheel on a 6" bench grinder ( I actually bought a 6" grinder just to do this but I figured I could always use it later. You can never have too many power tools. It has come in handy many times since). The wire wheel will get off all rust and crap. Be sure to wear a dust mask and eye protection. I usually don't but this **** will clog your nose and shoot specks of rust into your eyes if you don't. It will bring the caliper down to bare metal. Clean the calipers again with brake cleaner or a tack cloth to remove all dust and stuff. Mask off any rubber seals or holes where a bolt or pin will go through. Paint them with a good quality brake caliper paint ( made to withstand higher temps) that you can buy at your local automotive parts store. Put a couple good coats on them. If you really want to do it right, now would be a good time to rebuild your calipers to assure a long life and that they are in good working order. The rebuild kits can be bought here (fronts) http://www.hondaautomotiveparts.com/...y5=FRONT+BRAKE for $16.37 a piece .
Old Oct 22, 2002 | 04:47 AM
flrdaccrd's Avatar
Default Re: help with v6 caliper & rotor upgrade... (Wont be beat)
what! soap and water worked just fine for me before i painted mine.
some painted calipers look silly. for example, a black car with green paint or yellow car with red paint. i have a black accord and red caliper paint looks kill
Old Oct 22, 2002 | 08:15 AM
bmm89's Avatar
Default Re: help with v6 caliper & rotor upgrade... (flrdaccrd)
i agree with the paint, and dawn worked great... anycase, the luxury brands come with their calipers painted anyway, just for corrosion resistance, not only looks
beat_nut
Dec 13, 2004 09:48 PM
B2FiNiTY
Jul 19, 2004 10:11 AM
red00gsr
Feb 2, 2002 09:00 AM
