94 Civic - need help reading CEL code
i just bought a 94 vx hatch. when i got it the cel did not have a bulb in it so i put one in and the light stays on. so i jumped the plug to get the code and all i get is one long light a long pause and then the long light again. any ideas. also the car has a z6 swap in it and everything is hooked up on it. the only thing not hooked up is the plug that went to the egr.
http://check-engine-light-codes.blog...retrieval.html I trust you know how to read them but, if not short blink=1 long=10 so: long long short short=22
like i said it's just one long blink a long pause and one long blink again no short blinks at all. would this be code ten AIT. sorry for the noob ? i am just so used to my 89 hatch being obd0.
did you read the list I gave you. the pause is the code cycle going again since you just have one code it will keep on repeating. remember one long blink=10 you're getting Code 10 Intake air temperature sensor(IAT). i was just explaning it with the code 22 thing i use that as it's easy to understand.
GsrVtec
Oct 19, 2006 07:33 AM
