5 1/4 Speakers fit in the front?
Old Oct 21, 2002 | 01:59 PM
Agent Daimon's Avatar
Default 5 1/4 Speakers fit in the front?
I have an 88 HB and wondering if 5 1/4 inch speakers would fit in the front?
thanks guys
Old Oct 21, 2002 | 02:09 PM
Aphrodavid's Avatar
Default Re: 5 1/4 Speakers fit in the front? (RIPDC2)
im an idiot, i have 6.5" in mine, for some reason i thought they were 5.25"
[Modified by DX-R, 3:50 PM 10/21/2002]
Old Oct 21, 2002 | 02:36 PM
johnzm's Avatar
Default Re: 5 1/4 Speakers fit in the front? (DX-R)
i got 6 1/2 in mine.....
Old Oct 21, 2002 | 02:58 PM
technine's Avatar
I thought stock was 5 1/4? Got that in mine and also a set of aftermarket ones also, but I did have to cut out the back of the basket to make it fit because of the larger magnet.
Old Oct 21, 2002 | 03:28 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
I got 6 1/2's in mine. Where can I mount rear speakers in my DX hatch?
Old Oct 21, 2002 | 05:43 PM
performula's Avatar
Default Re: 5 1/4 Speakers fit in the front? (SeaBass)
Those little indentions in the rear, near the seat belt slider is where you can mount rear speakers.
I have 6.5 in the front, I'll double check tomorrow.
Old Oct 21, 2002 | 07:01 PM
PhatOptimo's Avatar
Default Re: 5 1/4 Speakers fit in the front? (performula)
i have 6" in the doors and the window will only roll down a little over half way. Its cool because I never roll them down all the way anyway.
Old Oct 21, 2002 | 07:48 PM
Crxer's Avatar
Default Re: 5 1/4 Speakers fit in the front? (Phat_Optimo)
i got 6 1/2 polk ex speakers in the front and back
they fit fine, the screws didnt match up properly though.
the components sound great as long as you have a decent amp on them.
Old Oct 21, 2002 | 07:59 PM
EF_LSVtec's Avatar
Default Re: 5 1/4 Speakers fit in the front? (Crxer)
technine is right, depends on the magnet. The book says 6 1/2 but I once put a 6 1/2 speaker made by bazooka and had to take em off because magnet was too big. I have 6 1/2 a/d/s separates now and it fits well. Only mod I did was replace the mounting bracket to match the holes...but same size.
Old Oct 21, 2002 | 09:12 PM
civicracer13's Avatar
yea 5 1/4 work i have shitty 5 1/4 sony expoids in the doors of my 89 hatch
Old Oct 21, 2002 | 10:35 PM
Louie B.'s Avatar
Did you take the plastic spacers out and mount the speakers directly to the metal door??? Most 6's, with a few extreme exceptions, will clear the windows if you use the spacers.
Honda made pods that mounted to the wings of the hatch cover to hold a 6", I'm not sure if they're still available from honda or not, but I do see them on Ebay from time to time.
By the way, in case your wondering, the factory rear speaker wires are tied back by the taillight wires behind the little covers in each corner of the hatch... Red and brown on the right (red positive) and blue and grey on the left (blue positive)
As for the original question, 5.25" speakers will work, but the hole is designed for 6", that means there will be an air gap around the speaker robbing you of almost all of your lower frequencies. one way around this is to take out the stock plastic spacer and build a new spacer out of 1/2" MDF. Cut the outside to the same dimensions as the plastic spacer, and make the inside hole the proper size for your 5.25's. You will need to paint the MDF or even better, coat it with fiberglass resin to waterproof it.
[Modified by thumpu77, 11:41 PM 10/21/2002]
Old Oct 21, 2002 | 10:40 PM
spettinger's Avatar
Default Re: 5 1/4 Speakers fit in the front? (thumpu77)
just cut out the stock baskets and mount the 6.5"s to it. you need the spacing and vibration dampening from the basket, otherwise you will have window issues.
Old Oct 22, 2002 | 05:40 AM
2_Jay_Z's Avatar
They should fit!
Old Oct 22, 2002 | 09:33 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 5 1/4 Speakers fit in the front? (wreckedhatch)
exactly. if you can work on a car, you can install speakers.
killercrx91
Mar 30, 2009 09:18 AM
Joecivic94
Audio / Security / Video
Aug 28, 2007 11:47 AM
rah350z
19
May 20, 2007 06:10 AM
baaba2007
Honda Fit
Mar 12, 2007 06:21 PM
shipsaeki
May 29, 2003 07:05 AM
