EF SI PROBLEM
Old Feb 22, 2013 | 07:22 PM
CIVIC9922's Avatar
Default EF SI PROBLEM
Well the other day i was sure my alternator went bad so I replaced it with a reman one.Then on the way home from work tonight it started to do the same thing,while driving the headlights and dash lights started to dim and radio shut off and when I pushed on the throttle the it cut out. While to car was off but key on when the radio came back on i was able to start the car but as it idled the headlight dimmed and then it died again ???/
Old Feb 22, 2013 | 08:14 PM
CIVIC9922's Avatar
Default Re: EF SI PROBLEM
well pretty sure the alternator is crap when i check it with a volt meter only putting out 11.8v and when i disconected battery car dies
Old Feb 22, 2013 | 08:49 PM
Former User's Avatar
Does the charge system light in the cluster remain on while driving?
Have you tested the large alternator wire that runs to the hood fuse box?
JDM-ish
12
Dec 8, 2011 01:28 PM
netfreak
Sep 19, 2010 05:36 PM
jdm2000civic
14
Sep 10, 2009 01:21 PM
EG93si
Jul 21, 2005 09:04 PM
shadowdawn
Aug 9, 2003 06:23 PM
