Oil catch can design help
Er no. It's a filter for filtering your filter. All you're saying is your design is inadequate and that was the only thing you could come up with to address a design flaw-ie the baffle isn't long enough.
That was the option that i can think of. Do you have any other suggestions then? Or think that single chamber baffle is enough and keep the tank as is without the stainless mesh and extra filter?
I hear your criticism and justifiable they are but any suggestions?
I have an external water pump under my intercooler charge pipe so the can cant be attached to the passenger strut tower and there is no room anywhere on the firewall so I have to build an extension bracket from the firewall to mount below my intercooler pipe where it meets my throttle body and there is limited space under there.
I am restricted by heights not by width there...
And I am not removing my battery to put a catch can there.
How is it an existing design? You drew a picture of it?
In your other thread you state "This is what I plan on doing for my oil catch can. Sorry for the shitty drawing and hope you get the idea."
You didn't say you were modifying an existing design/catchcan. And don't forget, YOU asked for criticism. And the suggestion is blatantly obvious; ditch the idea of another filter since it makes absolutely no sense.
I'll just leave this thread as be and figure it out by myself from what has been said. Thanks for your help.
^^ I'd like to see one of those. Thats a neat design.
I've done this using these parts. It worked, but because the catch containers are so small I was constantly draining oil out of it and if you aren't paying alot of attention to it it fill ups quickly and creates blockage easily. Beware if using this one.
Noch
Jul 26, 2008 01:47 PM
Boilermaker1
May 3, 2005 08:32 PM
2000vsm
Oct 2, 2003 06:22 PM
