500+ Honda/Acura Parts!
I have over 500 Honda/Acura Parts
I have pictures of everything but it will be too much to load. If interested in a parts please PM or Call Text/(803-600-8347) Parts are somewhat firmish NO TRADES and no I WILL NOT Meet you.
To search parts you can use the search button in your browser!
Before people go bashing my thread I have Titles to vehicles purchased that these parts came off of. I will gladly post them!
ARIAS PISTONS D SERIES 92-95 $60
ARP HEAD STUDS D16Z6 92-95 $SOLD
AUTOMETER GUAGE WATER TEMPERATURE $SOLD
B16 BARE BLOCK JDM B16 $100
B16 INTAKE MANIFOLD OBD0 $50
B16 ROCKER ARM ASSEMBLY JDM B16 $115
B16 STOCK VALVE SPRINGS JDM B16 $50
B16 VALVE COVER JDM B16 $SOLD
B16 VTEC SOLENOID JDM B16 $60
BOV PIPING UNKNOWN $20
CIVIC 2 DOOR OUTER TAIL LIGHTT 96-98 $20
CIVIC 2 DR PASSENGER SIDE WINDOW REGULATOR 96-00 $50
CIVIC 2DR REAR SEATS 96-00 GRAY $50
CIVIC 4 DOOR LX DX EXHAUST MID SECTION 96-00 $40
CIVIC 4DR SUN VISORS 92-95 TAN $25
CIVIC 5 SPEED REAR T BRACKET 92-95 $40
CIVIC AC BRACKET 96-00 $30
CIVIC AC BRACKET 88-91 $30
CIVIC AC COMPRESSOR 88-91 $35
CIVIC AC FAN 88-91 $20
CIVIC AC MOUNT 96-00 $25
CIVIC AFTER MARKET HEADER B16 4-1 99-00 $60
CIVIC AFTER MARKET HEADER D16 4-2-1 96-00 $50
CIVIC ALTERNATOR BRACKET 92-00 $15
CIVIC ALTERNATOR BRACKET SET SI B SERIES 99-00 $35
CIVIC ALTERNATOR D SERIES 92-95 $35
CIVIC ALTERNATOR D SERIES 96-00 $35
CIVIC ANTENNA 96-00 $10
CIVIC AUTOMATIC FRONT TRANSMISSION BRACKET 96-00 $10
CIVIC AUTOMATIC TRANSMISSION UPPER MOUNT BRACKET 96-00 $20
CIVIC B16 PARTS DISTRIBUTOR 92-95 $20
CIVIC BOTTOM TIMING COVER D SERIES D16A6 88-91 $15
CIVIC BREATHER BOX 92-95 $15
CIVIC CENTER CONSOLE COVER 96-00 GRAY $15
CIVIC CLIMATE CONTROL 96-98 $30
CIVIC CLUTCH AND PRESSURE PLATE AFT 6 PUCK 92-00 $40
CIVIC CLUTCH FORK 92-00 $15
CIVIC CLUTCH MASTER CYLINDER 92-95 $25
CIVIC COIL PACK D17 01-05 $10
CIVIC COIN TRAY 96-98 $5
CIVIC CRANK PULLEY 96-00 $35
CIVIC CRANK PULLEY 92-95 $25
CIVIC CRUISE CONTROL UNIT 92-95 $25
CIVIC CRUISE CONTROL UNIT 96-00 $25
CIVIC CYK SENSOR 96-98 $10
CIVIC D SERIES NON VTEC VALVE COVER D15 88-00 $20
CIVIC D SERIES VALVE COVER D16 96-00 $35
CIVIC D15 STOCK HEADER 92-95 $30
CIVIC D16 DISTRIBUTOR 96-98 $40
CIVIC DASH SIDE COVERS 96-00 $15
CIVIC DPFI PARTS DISTRIBUTOR 88-91 $20
CIVIC DPFI PARTS DISTRIBUTOR 88-91 $15
CIVIC DRIVER SIDE AXLE D SERIES 5 SP 96-00 $30
CIVIC DRIVER SIDE AXLE D SERIES 5 SP 01-05 $30
CIVIC DRIVER SIDE POWER MIRROR 96-00 $25
CIVIC DRIVERS SIDE HEADLIGHT 96-98 $25
CIVIC DRIVERS SIDE HEADLIGHT 88-91 $85
CIVIC DRIVERS SIDE MOUNT 96-00 $35
CIVIC DX 5 SPEED ECU P2E 337 96-98 $60
CIVIC DX 5 SPEED ECU PM5 A30 88-91 $25
CIVIC DX CX EX DISTRIBUTOR 96-98 $40
CIVIC DX LX 5 SP PARTS HARNESS 96-00 $30
CIVIC DX LX CX EX PARTS DISTRIBUTOR 96-98 $25
CIVIC DX LX D16Y7 THROTTLE BODY 96-00 $20
CIVIC DX LX GAUGE CLUSTER 5 SPEED 96-00 $35
CIVIC E-BRAKE HANDLE 92-95 BLACK $15
CIVIC ENGINE D15B2 88-91 $100
CIVIC ENGINE HARNESS B16 99-00 $85
CIVIC EX AUTO ECU P2P 366 96-98 $65
CIVIC EX AUTO ECU P2P A92 99-00 $100
CIVIC EX D16Y8 FUEL RAIL 96-00 $50
CIVIC EX D16Z6 FUEL RAIL 92-95 $30
CIVIC EX INTAKE MANIFOLD D16Y8 96-00 $100
CIVIC EX INTAKE MANIFOLD D16Z6 92-95 $75
CIVIC EX PARTS DISTRIBUTOR 99-00 $25
CIVIC EX STOCK AIR BOX D16Y8 96-00 $40
CIVIC FLOOR FOOT REST 92-95 $10
CIVIC FLWHEEL 88-00 $25
CIVIC FRONT BUMPER LENSES 88-91 $20
CIVIC FRONT REINFORCEMENT BAR 88-91 $35
CIVIC GAUGE CLUSTER BEZEL 96-00 $20
CIVIC HATCH REAR GLASS 92-95 WITH SHOCKS $100
CIVIC HATCH REAR WINDOW DRIVER SIDE 88-91 $100
CIVIC HATCH REAR WINDOW PASS SIDE 88-91 $100
CIVIC HATCHBACK DRIVERS SIDE TAIL LIGHT 96-98 $40
CIVIC HATCHBACK EK4 FRONT AND REAR BUMPER SET 96-98 WHITE $500
CIVIC HATCHBACK FRONT BUMPER 88-91 $50
CIVIC HATCHBACK FRONT CORNER LENSES 88-91 $25
CIVIC HATCHBACK PASSENGER SIDE TAIL LIGHT 96-98 $40
CIVIC HATCHBACK REAR INNER TAIL LIGHT 88-91 $40
CIVIC HATCHBACK REAR WING STOCK 88-91 $45
CIVIC HATCHBACK REAR WING STOCK 96-00 $20
CIVIC HATCHBACK REAR WIPER MOTOR 88-91 $15
CIVIC HATCHBACK TOP REAR SEATS 88-91 TAN $40
CIVIC HATCHBACK TRUNK LATCH 88-91 $15
CIVIC HATCHBACK TRUNK LOCK WITH KEY 88-91 $15
CIVIC HB SUSPENSION TECHNIQUES FRONT AND REAR SWAY BARS 96-00 $125
CIVIC HEAT SHIELD 92-95 $15
CIVIC HOOD LATCH 88-91 $10
CIVIC HOOD LATCH LEVER 92-95 $5
CIVIC INTAKE AIR BOX 88-91 $40
CIVIC INTAKE MANIFOLD D17 01-05 $50
CIVIC INTAKE MANIFOLD PLATE 01-05 $15
CIVIC INTAKE MANIFOLD SI CRX 88-91 $60
CIVIC INTEGRA DISTRIBUTOR CAP 92-95/94-01 $5
CIVIC INTEGRA H22 SWAP MOUNTS 92-95/94-01 $60
CIVIC LOWER TIMING COVER D16 96-00 $15
CIVIC LX DX ECU AUTOMATIC PM5 A81 88-91 $20
CIVIC LX DX FUEL RAIL D16Y7 96-00 $20
CIVIC LX DX HEAD D16Y7 `96-00 $60
CIVIC LX DX INTAKE MANIFOLD D16Y7 96-98 $25
CIVIC OEM JACK 88-00 $15
CIVIC OXEGYN SENSOR 96-00 $30
CIVIC PASS SIDE HEAD LIGHT 96-98 $25
CIVIC PASS SIDE HEAD LIGHT 88-91 $85
CIVIC PASSENGER SIDE AXLE 96-00 $25
CIVIC PASSENGER SIDE TAIL LIGHT SI 05-09 $60
CIVIC PASSENGER SIDE TORQUE MOUNT 96-00 $25
CIVIC POST MOUNT 92-95 $20
CIVIC POST MOUNT 96-00 $25
CIVIC POST MOUNT 92-95 $30
CIVIC POWER DOOR LOCK SWITCH NEW 96-00 $10
CIVIC POWER STEERING ALTERNATOR POST MOUNT 01-05 $35
CIVIC POWER STEERING BRACKET 88-91 $20
CIVIC POWER STEERING BRACKET 96-00 $20
CIVIC POWER STEERING BRACKET 92-95 $20
CIVIC POWER STEERING BRACKET D15 92-95 $20
CIVIC POWER STEERING PUMP 92-95 $25
CIVIC POWER STEERING PUMP D SERIES 96-00 $25
CIVIC POWER STEERING PUMP D SERIES 92-95 $25
CIVIC POWER STEERING RESIVOIR 96-00 $20
CIVIC POWER STEERING RESIVOIR 92-95 $20
CIVIC RADIATOR FAN 88-91 $20
CIVIC RADIATOR OVER FLOW TANK 92-95 $10
CIVIC REAR LIP 96-98 $35
CIVIC REAR MAIN HOUSING D SERIES 88-00 $15
CIVIC REAR MOUNT 96-00 $15
CIVIC REAR MOUNT 92-95 $15
CIVIC REAR T BRACKET 96-00 $30
CIVIC SHIFT **** 92-00 $10
CIVIC SI B16 CRANK SHAFT 99-00 $125
CIVIC SI BACK TIMING COVER B16 99-00 $15
CIVIC SLAVE CYLINDER 92-95 $8
CIVIC SPEED SENSOR D SERIES 5 SPEED 92-00 $20
CIVIC SPEED SENSOR D SERIES 5 SPEED 92-95 $20
CIVIC STARTER 5 SPEED 88-00 $35
CIVIC STEERING COLUMN COVER 96-00 GRAY $25
CIVIC STEERING WHEEL 96-00 $30
CIVIC STIFFENER BRACKET B16 99-00 $15
CIVIC STOCK AIR BOX 92-95 $30
CIVIC STOCK COIL SPRINGS 96-00 $40
CIVIC STOCK REAR CAMBER ARMS 96-00 $10
CIVIC TIMING GEAR 96-00 $10
CIVIC TIMING GEAR D 96-00 $10
CIVIC TOP RADIATOR SUPPPORT 88-91 $30
CIVIC TOP TIMING COVER D16 96-00 $10
CIVIC TOP TIMING COVER SI B16 99-00 $20
CIVIC TRANSMISSION SIDE MOUNT 96-00 $20
CIVIC TRANSMISSION TORQUE MOUNT BRACKET 92-95 5 SPEED $40
CIVIC TRANSMSSION MOUNT 92-95 $20
CIVIC TRUNK LEVER GAS LEVER COVER 92-95 BLACK $5
CIVIC TRUNK REAR FILLER 88-91 $40
CIVIC UNDER BEZEL TRIM 96-00 GRAY $5
CIVIC UNDER DASH COVER 92-95 BLACK $30
CIVIC UNDER DASH COVER 96-00 GRAY $30
CIVIC VALVE COVER SI B16 GSR ITR 99-00 $60
CIVIC VTEC SOLENOID 92-95 $45
CIVIC VTEC SOLENOID 01-05 $35
CIVIC WATER TUBE AND THERMOSTAT HOUSING D16Y7 96-00 $35
CIVIC WINDOW CRANK ROLLERS 92-95 $10
CIVIC/INTEGRA REAR STRUT TOWER BRACE 92-95/94-01 $30
CRV AC BRACKET P7J 97-01 $75
CRV STARTER AUTOMATIC 97-01 $45
CRX EXHAUST MID SECTION 88-91 $40
INTEGRA 2 DOOR ALTEZZA TAIL LIGHTS 90-93 $25
INTEGRA 2 DOOR FRONT SPEAKER COVER 94-01 BLACK $10
INTEGRA 2 DOOR REAR BUMPER 90-91 BLACK $40
INTEGRA 2DR REAR GLASS PLASTIC TRIM SET 94-01 $30
INTEGRA 2DR SIDE SKIRTS 94-01 RED $45
INTEGRA 2DR SUNROOF 90-93 $100
INTEGRA 2DR SUNROOF 94-01 $100
INTEGRA 4 DOOR GAS DOOR 94-01 $10
INTEGRA 4 DOOR MUD FLAPS 94-01 $60
INTEGRA 4 DOOR PASS SIDE WINDOW SWITCH 94-01 $25
INTEGRA 4 DOOR PASSENGER FRONT WINDOW 94-01 $25
INTEGRA 4 DOOR PASSENGER REAR WINDOW 94-01 $25
INTEGRA 4 DOOR REAR BUMPER 94-97 WHITE $50
INTEGRA 4 DOOR TAIL LIGHTS 94-01 $50
INTEGRA 4 DOOR TRUNK FILLER 94-01 BLACK $25
INTEGRA 4DR DRIVER SIDE FRONT DOOR 94-01 WHITE $75
INTEGRA 4DR DRIVER SIDE FRONT WINDOW GLASS 94-01 $25
INTEGRA 4DR DRIVER SIDE REAR DOOR 94-01 WHITE $75
INTEGRA 4DR DRIVER SIDE REAR WINDOW GLASS 94-01 $25
INTEGRA 4DR EXHAUST HEAT SHIELD SET 94-01 $20
INTEGRA 4DR EXHAUST MID SECTION 94-01 $40
INTEGRA 4DR PASSENGER SIDE REAR DOOR 94-01 WHITE $75
INTEGRA 4DR SIDE SKIRTS 94-01 $60
INTEGRA 4DR SUNROOF 96-01 $100
INTEGRA 4DR TRUNK LID 94-01 WHITE $60
INTEGRA 5 SPEED PEDAL ASSEMBLY 94-01 $50
INTEGRA 5 SPEED UNDER DASH HARNESS 94-95 $40
INTEGRA ABS BRAKE MASTER CYLINDER 98-01 $40
INTEGRA ABS PROP VALVE 98-01 $10
INTEGRA AC BRACKET 90-93 $40
INTEGRA AC BRACKET LS GSR 94-01 $40
INTEGRA AC COMPRESSOR 96-01 $75
INTEGRA AC COMPRESSOR 96-01 $100
INTEGRA AC CONDENSER AND LINES 98-01 $60
INTEGRA AC FAN 90-93 $20
INTEGRA AC HEAT BLOWER MOTOR 94-01 $30
INTEGRA AC MOUNT 94-01 $35
INTEGRA AC PULLEY 94-01 $15
INTEGRA AC TENSIONER 90-93 $15
INTEGRA AC TENSIONER 94-01 $15
INTEGRA ALTERNATOR BRACKET SET GSR 94-01 $35
INTEGRA ALTERNATOR BRACKET SET LS 90-01 $30
INTEGRA ASH TRAY 94-01 $10
INTEGRA ASH TRAY CENTER CONSOLE 94-01 BLACK $10
INTEGRA AUTOMATIC FLEX PLATE 94-01 $20
INTEGRA AUTOMATIC GAUGE CLUSTER 90-93 $25
INTEGRA B18 B20 CHROME VALVE COVER 90-01 $30
INTEGRA B18 LS FUEL RAIL 94-01 $40
INTEGRA BACK TIMING COVER B18 LS 90-01 $10
INTEGRA BATTERY CHARGE HARNESS 94-01 $10
INTEGRA BOTTOM TIMING COVER B18 LS 90-01 $20
INTEGRA BRAKE MASTER CYLINDER AND BOOSTER 94-01 $50
INTEGRA BREATHER BOX GSR 98-01 $25
INTEGRA BREATHER BOX LS 94-01 $20
INTEGRA BREATHER BOX LS 90-93 $20
INTEGRA CAM GEARS B SERIES 90-01 $25
INTEGRA CENTER CONSOLE 90-93 BLACK $25
INTEGRA CHARCOAL CANISTER 90-93 $30
INTEGRA CHARCOAL CANISTER 98-01 $45
INTEGRA CIGARETTE LIGHTER GARNISH 94-01 $15
INTEGRA CLIMATE CONTROL AND BEZEL 94-01 $60
INTEGRA CLOCK 94-01 $10
INTEGRA CLUTCH AND PRESSURE PLATE 94-01 $30
INTEGRA CLUTCH CABLE 90-93 $20
INTEGRA CLUTCH MASTER CYLINDER 94-01 $25
INTEGRA CLUTCH MASTER CYLINDER RESIVOIR 94-01 $10
INTEGRA CRUISE CONTROL UNIT 94-01 $25
INTEGRA CRUISE CONTROL UNIT 90-93 $25
INTEGRA DASH VENT SUNROOF SWITCH 94-01 BLACK $10
INTEGRA DOOR LOCK ACTUATOR 94-01 $25
INTEGRA DRIVER SIDE AXLE B SERIES 5 SP 94-01 $25
INTEGRA DRIVERS SIDE KICKER PANEL 94-01 BLACK $15
INTEGRA DRIVERS SIDE KICKER PANEL 90-93 BLACK $20
INTEGRA DRIVERS SIDE MOUNT 94-01 $35
INTEGRA E-BRAKE CABLES 94-01 $50
INTEGRA E-BRAKE CONSOLE 90-93 BLACK $15
INTEGRA E-BRAKE HANDLE 94-01 $15
INTEGRA ECU COVER KICKER PANEL 94-01 BLACK $15
INTEGRA ECU COVER KICKER PANEL 90-93 BLACK $15
INTEGRA ENGINE BAY FUSE BLOCK COVER 90-93 $10
INTEGRA ENGINE BAY FUSE BLOCK COVER 94-01 $10
INTEGRA ENGINE HARNESS B18 5 SP 94-97 $85
INTEGRA ENGINE HARNESS B18 PARTS 94-97 $35
INTEGRA FAST IDLE THERMAL VALVE 94-95 $15
INTEGRA FLYWHEEL B SERIES 90-01 $30
INTEGRA FRONT BUMPER TIE DOWN BAR 94-01 $15
INTEGRA FRONT SEATS 94-01 BLACK $100
INTEGRA FRONT SWAY BAR 90-93 $40
INTEGRA GAUGE CLUSTER 94-01 $40
INTEGRA GAUGE CLUSTER BEZEL 94-01 BLACK $20
INTEGRA GAUGE CLUSTER BEZEL 94-01 $20
INTEGRA GSR BACK TIMING COVER B18 94-01 $20
INTEGRA GSR CKP SENSOR 98-01 $20
INTEGRA GSR CONNECTING RODS 94-01 $40
INTEGRA GSR CRANK SHAFT B18C1 94-01 $200
INTEGRA GSR INTAKE MANIFOLD B18C1 94-95 $65
INTEGRA GSR OIL PAN B18C1 94-01 $60
INTEGRA GSR THERMOSTAT HOUSING B18C1 94-01 $30
INTEGRA GSR WINDAGE TRAY B18C1 94-01 $25
INTEGRA HALF SHAFT 94-01 $85
INTEGRA HEAD B20/LS 90-01 $125
INTEGRA HEAT SHIELD 94-01 $25
INTEGRA HOOD LATCH 90-93 $15
INTEGRA HOOD LATCH LEVER AND CABLE 90-93 $20
INTEGRA HORN 94-01 $10
INTEGRA IACV B18 LS 94-01 $25
INTEGRA IGNITION AND SWITCH 94-97 $50
INTEGRA INTAKE MANIFOLD 94-95 $30
INTEGRA INTAKE MANIFOLD LS B18A1 90-93 $45
INTEGRA INTAKE MANIFOLD LS B18A1 90-93 $35
INTEGRA INTAKE MANIFOLD LS B18B1 96-01 $40
INTEGRA LOWER ALTERNATOR BRACKET 90-01 $15
INTEGRA LOWER TIMING COVER GSR 96-01 $25
INTEGRA LS POWER STEERING PUMP 94-97 $25
INTEGRA MIRROR COVER 90-93 $10
INTEGRA MODIFIED ENGINE HARNESS 98-01 $75
INTEGRA MT AUTO CRUISE 96-01 $20
INTEGRA MUFFLER BRACKET B SERIES 94-01 $5
INTEGRA NON VTEC DISTRIBUTOR 96-98 $40
INTEGRA NON VTEC DISTRIBUTOR 92-95 $40
INTEGRA NON VTEC DISTRIBUTOR 96-98 $30
INTEGRA PASSENGER SIDE AXLE B SERIES 5 SP 90-93 $30
INTEGRA PASSENGER SIDE MIRROR 90-93 BLACK $30
INTEGRA POST MOUNT 90-93 $35
INTEGRA POST MOUNT 94-01 $50
INTEGRA POWER STEERING BRACKET SET 90-93 $35
INTEGRA POWER STEERING LINES 98-01 $50
INTEGRA POWER STEERING PUMP 90-93 $40
INTEGRA POWER STEERING RESIVOIR 94-01 $20
INTEGRA PURGE AND MAP SENSOR ASSEMBLY 90-93 $25
INTEGRA REAR EMBLEM ACURA 94-01 $5
INTEGRA REAR MAIN HOUSING B SERIES LS B20 GSR 90-01 $20
INTEGRA REAR MOUNT 94-01 $20
INTEGRA REAR SPEAKER GRILLS 90-93 BLACK $50
INTEGRA REAR STRUT TOWER COVERS 94-01 BLACK $10
INTEGRA REAR SWAY BAR AND LCA'S 94-01 $100
INTEGRA REAR T BRACKET 5 SP 94-01 $45
INTEGRA REAR VIEW MIRROR 94-01 $25
INTEGRA SLAVE CYLINDER 94-01 $8
INTEGRA STARTER AUTOMATIC 94-01 $30
INTEGRA STEERING COLUMN 90-93 $40
INTEGRA STEERING COLUMN 94-01 $30
INTEGRA STEERING COLUMN COVER 94-01 BLACK $25
INTEGRA STEERING COLUMN COVER 90-93 BLACK $25
INTEGRA STEERING COLUMN W/ KEY 90-93 $45
INTEGRA STEERING WHEEL 90-93 BLACK W/ HORN $40
INTEGRA STIFFENER BRACKET GSR 94-01 $20
INTEGRA STIFFENER BRACKET LS 94-01 $15
INTEGRA STIFFENER BRACKET SET LS 94-01 $25
INTEGRA STOCK AIR BOX 94-01 $30
INTEGRA STOCK RADIATOR 94-01 $50
INTEGRA STOCK SPRINGS 94-01 $40
INTEGRA SUN VISORS 94-01 $25
INTEGRA SUNROOF VISOR 94-01 $40
INTEGRA SUSPENSION FORKS 90-93 $35
INTEGRA SUSPENSION FORKS 94-01 $25
INTEGRA THOTTLE CABLE GSR 94-01 $10
INTEGRA TIMING GEAR B 90-95 $10
INTEGRA TIMING GEAR B 96-01 $20
INTEGRA TOP POWER STEERING BRACKET LS B18 94-01 $20
INTEGRA TOP TIMING COVER B18 GSR 94-01 $20
INTEGRA TOP TIMING COVER B18 LS 90-01 $10
INTEGRA TRANSMISSION MOUNT 94-01 $25
INTEGRA TRUNK LEVER GAS LEVER COVER 94-01 BLACK $5
INTEGRA TYPE R OEM WRIST PINS NEW PART # 13112-P3F-000 $35
INTEGRA TYPE R STOCK HEADER 4-2-1 96-97 $150
INTEGRA UNDER DASH COVER 90-93 BLACK $30
INTEGRA UNDER DASH COVER 94-01 BLACK WITH FUSE COVER $40
INTEGRA UNDER GLOVE BOX COVER 90-93 BLACK $15
INTEGRA VALVE COVER LS B18 94-95 $40
INTEGRA VALVE COVER LS B18 90-93 $30
INTEGRA VALVE COVER LS B18 B20 96-01 $40
INTEGRA VALVE COVER LS B18 B20 96-01 $45
INTEGRA WATER TUBE AND THERMOSTAT HOUSING B18 94-01 $50
INTEGRA WINDAGE TRAY B18 LS 90-01 $20
INTEGRA WIPER MOTOR ASSEMBLY 94-91 $20
JACKSON RACING SUPER CHARGER PULLEY AND BRACKET B18 AFTERMARKET $75
JDM B16 CONNECTING RODS JDM B16 $40
OBD2B TO OBD1 JUMPER HARNESS $25
PRELUDE 5 SPEED PEDAL ASSEMBLY 92-96 $50
PRELUDE ABS MODULE 92-96 $30
PRELUDE AC COMPRESSOR 92-96 $80
PRELUDE BATTERY TRAY 92-96 $20
PRELUDE BOTTOM AIR BOX ASSEMBLY 92-96 $40
PRELUDE BRAKE MASTER CYLINDER AND BOOSTER 92-96 $50
PRELUDE BUMPER REINFORCEMENT BAR 92-96 $40
PRELUDE BUMPER VENTS 92-96 $75
PRELUDE CENTER CONSOLE 92-96 BLACK $35
PRELUDE CLUTCH MASTER CYLINDER 92-96 $25
PRELUDE DIGITAL GAUGE 92-96 $75
PRELUDE DIGITAL GAUGE HARNESS 92-96 $40
PRELUDE DRIVER SIDE AXLE H SERIES 5 SP 92-96 $40
PRELUDE DRIVER SIDE DOOR 92-96 GREEN $100
PRELUDE DRIVER SIDE MIRROR 92-96 TEAL $40
PRELUDE DRIVERS SIDE KICKER PANEL 92-96 BLACK $25
PRELUDE DRIVERS SIDE TAIL LIGHT 96-98 $40
PRELUDE E-BRAKE HANDLE 92-96 BLACK $15
PRELUDE ENGINE BAY FUSE BLOCK COVER 92-96 $10
PRELUDE FLOOR FOOT REST 92-96 $10
PRELUDE FRONT AND REAR SWAY BAR 92-96 $60
PRELUDE FRONT SEATS 92-96 BLACK $100
PRELUDE FRONT TRANSMISSION BRACKET 92-96 $15
PRELUDE GAS DOOR 92-96 $10
PRELUDE GLOVE BOX 92-96 BLACK $50
PRELUDE H22 ENGINE HARNESS PARTS 92-96 $15
PRELUDE H22 VTEC DISTRIBUTOR 92-96 $50
PRELUDE HOOD LATCH 92-96 $20
PRELUDE HORN SET 92-96 $15
PRELUDE IGNITION AND IGNITION SWITCH 92-96 $50
PRELUDE LIGHT SWITCH 92-96 $20
PRELUDE MAIN RELAY 92-96 $10
PRELUDE MIRROR COVER 92-96 $10
PRELUDE MOON ROOF 92-96 TEAL $100
PRELUDE MT AUTO CRUISE 92-96 $20
PRELUDE PASSENGER SIDE AXLE H SERIES 5 SP 92-96 $40
PRELUDE PASSENGER SIDE TAIL LIGHT 96-98 $40
PRELUDE POWER STEERING COOLER 92-96 $15
PRELUDE POWER STEERING RESIVOIR W/ BRACKET 92-96 $25
PRELUDE RADIATOR OVER FLOW TANK 92-96 $15
PRELUDE REAR BUMPER 92-96 TEAL $45
PRELUDE REAR GLASS PLASTIC TRIM SET 92-96 $40
PRELUDE REAR QUARTER PANEL PLASTICS 92-96 BLACK $50
PRELUDE REAR SEAT CENTER CONSOLE 92-96 BLACK $80
PRELUDE REAR SEATS 92-96 BLACK $80
PRELUDE REAR VIEW MIRROR 92-96 $25
PRELUDE RESISTOR BOX 92-96 $25
PRELUDE ROOF RUNNERS 92-96 GREEN $35
PRELUDE SEAT BELT SET 92-96 $50
PRELUDE STEERING COLUMN COVER 92-96 BLACK $20
PRELUDE STEERING COLUMN W/ TILT 92-96 $30
PRELUDE STOCK REAR WING 92-96 TEAL $60
PRELUDE STRUTS AND SPRINGS 92-96 $100
PRELUDE SUBFRAME 92-96 $40
PRELUDE SUN VISORS 92-96 $25
PRELUDE SUSPENSION FORKS 92-96 $25
PRELUDE THERMOSTAT HOUSING H22A1 92-96 $25
PRELUDE TRANSMISSION MOUNT 92-96 $35
PRELUDE TRUNK LID 92-96 TEAL $75
PRELUDE TRUNK/GAS LEVER 92-96 $15
PRELUDE WIPER ARM ASSEMBLY 92-96 $20
PRELUDE WIPER ARMS 92-96 $20
RSX FLYWHEEL 05-06 $45
RSX FOG LIGHTS 02-04 $50
RSX INTAKE MANIFOLD BRACKET 05-06 $5
Bad seller, don't buy from, paid him for an item and he claims he shipped but can't provide a tracking number. He won't reply to my text or refund my money. It's a scam, buyers beware.
