ZC motor - broken rocker arm
Old Feb 22, 2013 | 08:54 AM
JDMarkLangston's Avatar
Icon6 ZC motor - broken rocker arm
I got a 95 civic with ZC swap. Boosted at 8ibs this is what's done to the car:
Vitara pistons
Eagle rods
Eagle crank
Skunk2 cams with OEM cam gears
50mm turbo
Arp head studs
Cosmetic head gasket
Today I was runnin another civic but after racin my car just shut off. It wouldn't kick back over and I pulled over. Checked under the hood. It was good. Checked oil it was good. Then I took off the valve cover and the 2nd rocker arm near the intake manifold wasnt there. I looked around and the spring represser was cracked In half and there was a two piece ring sorta thing? Idk what it was but I kno it was a two piece set. Not cracked.
I ordered the spring represser from Honda but I'm worried if it bent valves or did any internal damage? Any ideas you guys? Any input?
Old Feb 22, 2013 | 09:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ZC motor rocker arm
Pull the head and stop wondering if there's damage or not.
oldskool88291
11
Dec 31, 2007 06:29 AM
Hondaidiot
Dec 2, 2007 12:13 PM
bigfuhrm
11
Jul 13, 2005 04:37 PM
keithv
18
Mar 9, 2003 05:32 PM
