is my tranny toast?
Old Feb 21, 2013 | 05:01 PM
thecayub's Avatar
Default is my tranny toast?
Hey guys, this might have been a problem that's been discussed but I cant seem to find one similar to mine.
I have a 1991 Civic hatchback dx
It is a non vtec with an automatic transmission.
Here's the deal: the car starts and drives great, transmission will shift great and hold power... for around 2 miles, then (once transmission gets warmed up), it starts to slip and will not hold any power without slipping.
If you let it sit and cool down, it will work perfect again til it warms up.
Trans fluid is topped up, and not a bad color (red, but approaching red-brown).
are the clutch packs toast?
Thanks
Old Feb 21, 2013 | 10:14 PM
skill178's Avatar
Default Re: is my tranny toast?
could be anything in there really, but working until it gets warm makes me think of something along the lines of a torque conv.
ever thought of converting to a 5spd? (or 4spd std)
can pick up a good 88-91 tranny around here for $50-$100 (just watch out for 88's with a different clutch)
Old Feb 22, 2013 | 09:31 PM
thecayub's Avatar
I think that it's clutch packs because if it were torque converter wouldnt it shudder/vibrate terrible? But that's why I am asking others advice
I've considered a 5spd swap but I need shifter, pedals, clutch, cv's and a computer correct? It's more complication than I want right now. I want to get it operable and sell it as is.
Thanks for the reply
Old Feb 22, 2013 | 10:13 PM
Former User's Avatar
The transmission is probably toast, but first try doing three drain and refill cycles with Honda ATF.
Old Feb 23, 2013 | 03:10 PM
rd91sib18c5r's Avatar
Have you tried to adjust the shift cable, if you tighten it some it will shift firmer.
Old Feb 23, 2013 | 09:01 PM
thecayub's Avatar
My shifter seems to be fine? It shifts into reverse neutral d4 d3 and d2 just fine it's just that once the Trans "warms up" it begins to slip. It's probably toast. I don't wanna waste the money on all that ATF, I tracked down a use tranny I'm gonna throw in.
Jz6m
Jul 14, 2011 07:17 PM
az90civic
27
Oct 29, 2007 01:32 PM
93civcx
Apr 27, 2004 03:50 AM
OldSchoolCrxSiR
11
Jun 23, 2002 04:16 PM
