Help! 99 Civic with JDM GSR won't turn over...
Recently I removed my vtec solenoid to replace gaskets. I took off the distributor first to make it easier. Removed solenoid and replaced gaskets. After I put everything back it turns over but will not start. Also I removed distributor cover and found a rusty screw and chunks of plastic in it. I've replaced the cap and rotor but still no go. Any suggestions??
No its just that piston inside the solenoid has a oil oriffice located at a certain area that must be lined up with the corresponding oriffice on the top half of the solenoid before re-assembeling the soilenoid.
Check to make sure this is correct,
If not it is possible that the VTEC is locked,
And starting your car can be kinda hard when locked on high cam.
If this is not the issue,
You have something inside the distributor assy that is obviously compromised.
Or compromised wiring most likely created while doing the job.
IIRC,
If you keep trying with some throttle input, it will try to start, and stumble around.
But never completely start up, hold idle, ect.
Just sounds cammed up from hell when it does try to start.
Inspect the little piston pushing it down gently into the lower half of the solenoid with your thumb, if it moves freely and doesnt hang up or feel notchy then your good.
Look at the upper half now and note where the orrifice (little hole) lies.
now simply spin the piston while its in place and clock the orrifice to its correct position you previously noted.
re assemble
re install
And make sure you didnt have a hondabond party and possible clog any of these important oil orrifices/galleys
re assemble
re install
You need to check for spark and fuel in that order.
Also after cranking it over for 10-20 seconds does the CEL illuminate, if so what codes are present.
Why did you have the distributor off, and did it work prior to its removal?
Everything done to the distributor needs to be correct, parts, assy, being cautious of not breaking anything, ect.
Use another known good unit to test if you can
Does the fuel pump prime?
Does the CEL remain on steady when you turn the key from off to ON(II) or does it turn of after 2 seconds?
Does voltage reach the coil inside the distributor.
Remove the coil and ICM from the distributor. Resistance test the coil.
Have AutoZone test the ICM.
If it is stumbling and trying to start my guess is your firing order is off on the dizzy or you replaced the dizzy 180 degrees off, very easy to connect the wires in the wrong order. If its nots firing at all i would check the ground by your tranny, might have knocked it loose. And try the one on the thermo housing under the dizzy.
Good practice to mark where distributor is @ before you pull it- too late I know. Next time you get it fired up set timing and make a mark on top where bolt goes with a scredriver or something sharp this way it doesn't rub off. Scratch it across the aluminum above top bolt where cyl head sticks up
Installing a distributor 180 degrees out should be impossible. The base of the thing is only keyed to go on one way.
It can be done, but you really have to work at it, the distributor will shake like hell when turning the engine over and it will often break one prong off the distributor drive.
Vague
11
Jan 2, 2016 08:21 AM
5.4ever
10
Mar 6, 2014 05:27 PM
