methanol injection on all motor lsvtec
Old Feb 21, 2013 | 01:07 PM
williamwillie's Avatar
Default methanol injection on all motor lsvtec
Anybody running this on their all motor setups?
Old Feb 21, 2013 | 03:43 PM
xxjonxx4's Avatar
Default Re: methanol injection on all motor lsvtec
Not yet i will be considering the AEM kit once i get my allmotor build done. Looks like a legit set up for pump gas, gives you a lil more rum to play with timing. Check out AEMs website and go to there kit there is a cool video about it. Good luck
Old Feb 21, 2013 | 06:11 PM
I was looking at one from snow performance.net. I was wondering what's the highest compression I can run using 91 octane and meth injection on my lsvtec.
Old Feb 22, 2013 | 03:07 PM
MugenSpeclNY's Avatar
This was shown to me by a fellow HT member great tech articles
http://www.alcoholinjectionsystems.c.../articles.html
The main points are
Reduces air charge temperatures by 50-150+ degrees
Reduces cylinder temperatures by up to 300+ degrees
Increases your 87-93 octane pump gas by 8-20+ points
Allows you to safely run more boost and timing
Longer more stable combustion expansion and progression
Removes carbon build-up from combustion chambers, pistons and valves
Reduces and helps eliminate engine damaging detonation and pre-ignition
No need for expensive racing fuel or additives
Old Feb 22, 2013 | 06:43 PM
The main points are
Thanks
civic_66
23
Oct 25, 2008 05:22 PM
jdmb16ef8
Aug 19, 2007 03:10 PM
92 civic VX B18c
Jan 17, 2005 05:12 PM
B18G
16
Oct 28, 2003 04:10 PM
HX_Guy
Nov 2, 2001 11:38 AM
