What rod and main bearings do I need
Old Feb 21, 2013 | 09:08 AM
joiv21's Avatar
Default What rod and main bearings do I need
Doing lsv, I got the b18a1 block. If I get my crank polished do I need to go ahead and buy the .25mm over bearings or will standard size be fine? Or if you can explain a better route to do this.
Old Feb 21, 2013 | 02:35 PM
doood's Avatar
been there done that
Default Re: What rod and main bearings do I need
Measure the clearances. If you didn't know that I sure hope you're not putting this together yourself.
Old Feb 21, 2013 | 07:24 PM
1998GsRIntegra's Avatar
Give this thread a read before you TRY emphasis on try, to assemble the engine.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/blueprinting-need-advice-suggestions-input-3111498/
Old Feb 21, 2013 | 07:41 PM
98civdx's Avatar
Master Detailer
This isn't something that we can tell you. Every engine will be different.
Old Feb 21, 2013 | 09:16 PM
stowne78's Avatar
Take it to a machine shop if you don't know how to do it. Better safe than sorry.
Old Feb 23, 2013 | 03:06 PM
joiv21's Avatar
So I can take the rods, pistons, crank, block and all bearings to a machine shop and they'll do the right clearances? Do I buy just the standard size, that way they can clear as much as they need?
Old Feb 25, 2013 | 09:42 AM
stowne78's Avatar
Nooooooo. Take your block, rods, crank to the shop and they will tell you what size bearings to buy.
danimin
Dec 16, 2009 04:16 PM
rasta420
Apr 18, 2007 12:05 PM
hbyrd8701
Jul 28, 2006 04:24 AM
error
Jan 20, 2006 03:43 PM
1 Cam Wonder
Jan 24, 2005 08:29 AM
