K20 custom intake fitted now running like shit, vid inside, help please?
Old Feb 21, 2013 | 08:43 AM
Dan Page's Avatar
Default K20 custom intake fitted now running like ****, vid inside, help please?
I've just fitted a Venom custom intake on my K swapped EG. Previous it was running the standard intake and running bang on.
It's all connected up like the original however it has this problem. The revs are up and down drastically and when I connect this last breather it idles mega low or just goes too low and cuts out.
Anyone have any ideas?
Thanks
Dan
Old Feb 21, 2013 | 08:59 AM
B_Swapped93's Avatar
Default Re: K20 custom intake fitted now running like ****, vid inside, help please?
Could there be some dirt or "goo" in that little red tube ?. but do you mean the intake MANIFOLD or the little pipe with the filter(big diffrence when trying to help).
Old Feb 21, 2013 | 09:09 AM
Dan Page's Avatar
Intake manifold, the pipes brand new and it was the same with the OEM pipe on that one side. I'm starting to think it's a problem at the throttle body side now :/
Old Feb 21, 2013 | 09:17 AM
have you set the idle screw/are you using an aftermarket tb ? if aftermarket the screw won't be set for a proper idle. in this case looks like it's set to low ?(if it's a new aftermarket one) don't forget to calibrate the TPS if so. i had to fight with my tb screw to get a happy idle when i first got it my idle shot up to 4K rpm lol.
Old Feb 21, 2013 | 09:32 AM
Dan Page's Avatar
Using standard throttle body mate so no idle screw.
Throttle body is un touched kinda thing, bolted it off and bolted it back on with the new mani.
Old Feb 21, 2013 | 09:45 AM
Mine has an idle screw that's why I asked. if that's the case i really don't know what you would do kinda difficult without an idle screw imo.
Old Feb 21, 2013 | 10:48 AM
DazeMS's Avatar
so there is no way at all to adjust idle? Thats weird.. perhaps getting a ball valve and connecting it inline to the red hose and slowly let it leak(like a MBC) to raise your idle to the right level you desire.. done.
wild_wes5
Oct 25, 2013 09:42 PM
IDVirii
Mar 10, 2008 10:58 AM
90crxdriver
Jun 24, 2007 03:32 AM
jbell
Oct 26, 2005 11:46 AM
nateng
Aug 22, 2004 05:26 PM
