<<<<All motor D16 outrageous fuel pressure>>>>
Old Feb 21, 2013 | 07:02 AM
SinglecamMitch's Avatar
Default <<<<All motor D16 outrageous fuel pressure>>>>
rocking a civic si hatchback, D16 bottom end w/p29 high compression pistons(12:1) port and polished head, stainless steal valves stage 3 bisimoto race cam, high flow noc off header and junk 2 intake mani. trying to get this single cam tunned(on hondata s300) keeps leaning out around 5k rpms, after further looking into fuel pressure its and an OUTRAGEOUS 70 psi(on two gauges). these pressure readings were taking at fuel filter and fuel pump. changed the fpr, rerouted return and feed fuel lines, replaces fuel pump, fuel rail, fuel filter. some fallow up noticed while starting the engine using a battery charger(wisco cold weather) the fuel pressure would peak to 90 almost 100 psi!! in doing so changed out alternator, to find no change. anyone with some knowledge on these crazy fuel pressures, let me know.
Old Feb 21, 2013 | 09:06 AM
n*werk's Avatar
Default Re: <<<<All motor D16 outrageous fuel pressure>>>>
what size injector are you running? are you running an aftermarket fpr? where your vtec set at?
Old Feb 22, 2013 | 03:59 AM
bluetop 450s, and stock fpr, vtec is in gauged at 5200
Old Feb 22, 2013 | 04:44 AM
grumblemarc's Avatar
The Grumpiest
Get an adjustable FPR.
And the words are
tuning
engaged
steel
knock
taken
follow
If you're typing on your phone stop it.
Old Feb 22, 2013 | 07:19 AM
tried the adjustable FPR, did not help with bringing the psi down substantially only a few pounds.
Old Feb 22, 2013 | 08:19 AM
The Grumpiest
Don't see how that possible. What FPR? Sounds like you have no idea what you're doing with that Hondata.
Old Feb 22, 2013 | 08:29 AM
JustOneOrTwoPosts's Avatar
did you check the voltage coming into your fuel pump? You said you measured the pressure at the pump and it was high, must mean that your voltage supplied to the pump is high too..
Old Feb 22, 2013 | 08:52 AM
fcm's Avatar
fcm
Old Fart
The fuel return line is clogged. 94
Old Feb 22, 2013 | 09:15 AM
The Grumpiest
I bet you it's something that simple.
Old Feb 22, 2013 | 09:26 AM
fcm's Avatar
fcm
Old Fart
I can't see it being anything else. 94
Old Feb 23, 2013 | 10:16 AM
Brewcity95EJ1's Avatar
I had that same problem. Look into fcm's suggestion...our cold wisconsin weather doesn't help much when we need to fix our cars either lol
Element3488
12
Nov 19, 2012 08:53 AM
superhatchbackbros
Oct 7, 2006 10:51 PM
alexsracing
Jul 19, 2005 03:19 PM
Bantam
Mar 7, 2003 08:58 AM
Yuleluder
Jun 2, 2002 09:13 PM
