Hasport,Hallmen,SK2,P72,AEM &Parts 56k Never
Hey whats up Honda-Tech Ive Got some Parts Im Trying to Sell to Pay Bills And Finish Projects
PAYPAL Only
Located :Smithfield/Fairchance
Number 7two4-984-2168
-B16A SHORT BLOCK COMPLETELEY REBUILT 0 MILES...HAS B16B OIL COOLER SET UP ON IT &B16B OIL PUMP...King Bearings ,OEM Honda thrust washers ...NPR Rings $425.00 + shippin
-93 Civic DX OEM Rear Lower Control Arms...With Brand New Energy Suspenion Rear LCA Bushings (3) on Ebay Side...6 Total....TheseLCA With These Bushings Are Better,Stronger,Stiffer,Last Longer Better Then Any off Brand/Ebay Brand u Can Buy $60.00 Shipped
-D16Z6 OEM Crank Pulley..1 Tiny Baby Chipp $40.00 Shipped
D16Y8 OEM Crank Pulley....2 lil chipps $35.00 Shipped
B18A1 OEM Crank Pulley....The p.s is V style belt...$35.00 Shipped
-OBD2B to OBD1 ECU Jumper Harness...1 Pin is Pulled Out...Easy Fix...$25.00 Shipped
NOTE:1 P07 &P75 ECU SOLD & Some Ecu's Not Pictured
Chipped ECUS...Include a Chipp....With Basemap of Choice Wit Boost Cut at 5.5 PSI &Will Be Good Enough to Were u Can Drive to Get it Tuned.
-OBD0 Manuel PR4 B18A1 Ecu...$50.00 Shipped
-OBD0 Manuel PM6 D16A6 Ecu...$45.00 Shipped
-OBD1 Manuel P07-A00 Ecu $30.00 Shipped (Has Burnt Injector Resistor Needs a New One sidered in
-0BD1 CHIPPED Manuel P06...With BaseMap of Setup $105.00 Shipped
-OBD1 Chipped Manuel P28....With BaseMap of Setup $120.00 Shipped
-Random Parts...If Interested In Any of It Pm Me With Offer
D-Series Crank PulleY Bolts...$8.50 Shipped Each /B-Series Crank PulleY Bolt $12.50 Shipped Each
Map Sensors $32.00 Shipped Each /OEM Oil Pressure Sensor $8.50 Shipped Each
-B18B1 LS HYRDRO Gears...$25.00 Shipped Each
-HasPort B-series EF EndLink Knuckle For Trans..Nice Upgrade to ur Linkage Or Custom Linkage Make Sohc Linkage a Bseries with thisd...$22.50 Shipped
-Civic ,Integra Main Relays..All Tested...Perfect ...$25.00 Shipped Each MR
Civic ,Integra OEM Hood Latch Puller...On Left Side....(2)Available...$15.00 Shipped Each
-DelSol 4 WAY & Rear Defrost Button $14.00 Shipped Each
-92-95 Civic Rear Defrost Button $12.00 Shipped Eacj
-92 Civic Hazard Switch $15.00 Shipped
-B16,18 Long Pattern Pattern (Left Side)$25.00 Shipped Each
-D16z6,B18,B16 Normal Pattern (Right Side) $32.00 Shipped Each
-K20 Map Sensor up In Top Keft Corner/Includes Pigtails $40.00 Shipped
-JDM Sport Turbo(Needs Rebuilt) JDM Sport Manifold ,Backdoor Fmic ,Oil Lin,Oil fITING ,Block Fitting , Small Pipe $235.00 Shipped
PAYPAL Only
]-D16Z6 OEM Crank Pulley..1 Tiny Baby Chipp $40.00 Shipped
