03 Si needs new suspension
Old Feb 20, 2013 | 08:10 PM
posneon's Avatar
Default 03 Si needs new suspension
Hey guys, Just got rid of my built srt-4 for a 03 civic hatch. The guy that looked at both of our cars said the ep3 has nearly blown shocks on the right side, it also has skunk2 springs. Now I like the ride height but obviously coming from a coil-over setup on the srt to this i was looking for options. I don't think putting factory shocks back in will be beneficial. I also dont have 800+ to drop on coils. Was looking at koni yellows but idk alot about honda related suspension. BTW this is my DD, no track or AX. Thanks in advance guys.
Old Feb 20, 2013 | 08:23 PM
BluerEM2's Avatar
Default Re: 03 Si needs new suspension
Best for 1.5" drop is tokico blues, cheap and quality but won't go further.
Best for more is koni yellows. Install on them isn't easy though you need to modify the stock strut housing so make sure you know what your getting into.
Old Feb 20, 2013 | 08:45 PM
posneon's Avatar
what about upgrading to say bilstein shocks and keeping the springs. looking for a plug and play. also heard good and bad about racelands. his is just a dd commuter
Old Feb 21, 2013 | 12:16 PM
poeticfinesse21's Avatar
Ok a couple of things....
Junk2 springs are probably the worst springs out there aside from some no-name ebay springs. I recommend you get rid of those springs ASAP, they will only cause premature wear on whatever shocks you get.
Bilstein shocks are probably the best shocks that you can buy for the EP3 but...
They are valved for the stock spring rates. If you plan on using them with lowering springs then you will need to send them in to bilstein so they can be revalved to match whatever spring rates you are running. If you choose to not revalve them and use lowering springs then they will blow fairly quickly. Bilstein shocks are also not cheap. It's about $800 for all four shocks and I believe it's $60 to revalve each one.
Stay far, far away from racelands. You're better off buying a used DC5 Type-R suspension off of ebay.
The best option for a daily driver? RSX a-spec suspension. $650 shipped:
http://www.curryacuraparts.com/pro.html
All you need to install them is RSX tie rod ends and the rear shock bushings will need about 3mm shaved off. There's a great DIY on ephatch on how to install them but that site has been down for a few days now
Old Feb 21, 2013 | 02:14 PM
posneon's Avatar
ok thanks. also I need to front mount my license plate. i see there are 2 holes in the grill but they are wider than the holes on the plate so Im guessing there was a bracket there. how can i mount it without covering up the foglight.
Old Feb 21, 2013 | 03:14 PM
Paul 631's Avatar
Although they will fit our cars, bilstein's sport/HD shocks are the same unit for non-SI civics as well (which have significantly lower spring rates)... chances are they will be under-dampened even when using stock EP3 spring rates.
Having Bilstein re-valve their shocks (even if they are new/uninstalled), will completely void their warranty.
Old Feb 21, 2013 | 03:50 PM
posneon's Avatar
i was reading about stock shocks and the eibach prokit. i don't need someting adjustable nor do i want a tokiko add on to shocks. just good shocks and a nice that won't blow and a nice drop.
Old Feb 21, 2013 | 08:09 PM
posneon's Avatar
c'mon guys, need to know where to get the bracket that goes from the 2 holes in the grill to the front plate. DOnt want to relocate because Im gonna be putting in fogs.
Old Feb 22, 2013 | 04:13 AM
TouringAccord's Avatar
H-T Order of Merit
the part you are looking for is #7 in the diagram below
it raises the plate so that it sits in front of the bumper cover, leaving the grill open
Old Feb 22, 2013 | 07:55 AM
posneon's Avatar
thanks man found it last night and ordered it.
Old Feb 22, 2013 | 04:03 PM
How is having bilstein revalve their own shocks going to void the warranty? That makes zero sense.
It says nothing on their site about their revalving service voiding their warranty:
http://www.bilsteinus.com/products/s...vice/warranty/
NAOK9688
Suspension & Brakes
Jul 25, 2010 07:40 PM
lcsej1
Suspension & Brakes
Apr 8, 2009 05:48 PM
Silent_Destruct
Apr 18, 2006 01:46 PM
gnar kill
11
May 7, 2005 08:42 AM
Mark Murda
16
Jan 13, 2004 04:09 AM
