SRS light on
Old Feb 20, 2013 | 05:51 PM
NilesLindenmuth's Avatar
Default SRS light on
So I took out my seats a couple days ago to shampoo and vacuum out my car. I reconnected all of the wires in their wire harnesses and bolted in my seats. I figured that the light would go away after a day or so. However, the light is still there.
Should I try to take them out and make sure the connection is right or...?
Any suggestions?
Old Feb 20, 2013 | 07:01 PM
HondaAccordKen's Avatar
Default Re: SRS light on
Did you turn on the ignition with the seats unplugged? Then you might need to have it reset. Make sure you did not pinch any wires reinstalling the seats.
Was able to reset my 98 accord with my friends new scanner at his shop after replacing the clock spring. It's Windows CE tablet type unit. If your local shop can't do it you need to have a dealer to do it.
Old Feb 20, 2013 | 08:51 PM
NZXTInerTia's Avatar
What do the seats and the SRS have to do with each other? Do we have weight sensors? If your horn doesn't work its the clock spring. Otherwise you would need a more refined description.
Old Feb 21, 2013 | 03:45 AM
Ill head up to autozone today and get them to pull the codes. I'll get back to y'all
Old Feb 21, 2013 | 03:58 AM
djkurious's Avatar
Year, make, model..?
Old Feb 21, 2013 | 04:21 AM
gqstatus05's Avatar
My SRS light has been on for a year on my 96 Accord. I haven't gotten around to looking into it but will get it sorted out next month when the weather breaks.
Old Feb 21, 2013 | 07:10 PM
2001 Honda accord v6 3.0
Old Feb 22, 2013 | 05:26 PM
WHEEELMAN's Avatar
http://www.v6performance.net/forums/...-miss-you.html
It's in the seatbelt connection. When you disconnected the seat belt plug, i'm thinking the signal was interrupted and you tripped the SRS system.
Use the link above to reset it.
Old Feb 23, 2013 | 08:45 PM
Thank you so much!
Old Apr 1, 2013 | 02:43 PM
tkrisher's Avatar
Perfect
sudorc
Honda Civic (2001 - 2005)
14
Apr 17, 2024 06:32 AM
dvnsandman
Mar 5, 2007 07:30 AM
egdinger
Jul 24, 2005 03:47 PM
wanganator
Oct 26, 2004 03:17 PM
eg_nezay
13
Mar 3, 2003 06:13 AM
