1st time head gasket replacement..
Old Feb 20, 2013 | 02:12 PM
giovannie23's Avatar
Default 1st time head gasket replacement..
1997 honda accord f22b2 its my first time replacing the head gasket and i wanted to see if anyone had any tips and things i should do that they dont explain in the servicemanuel the littlest tip would maybe make a big difference thanks
Old Feb 20, 2013 | 08:55 PM
NZXTInerTia's Avatar
Default Re: 1st time head gasket replacement..
Just make sure you remove and install the bolts in a specific order. Then you have to be able to do a valve adjustment correctly, most people attempt to do them by themselves and generally make things worse. Finally make sure your timing is correct and the belt is tightened completely.
Here's the order for the head bolts.
Read this ENTIRE thread. It will help you quite a bit.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-headgasket-f22b2-2335661/
Old Feb 21, 2013 | 12:08 PM
codeblaster's Avatar
Take em off in the right criss-cross order, then replace gasket, and put the bolts on the same way you took em off. Very easy on a honda.
You may want to use a straight edge and a feeler gauge to check of the head or block top is warped. The heads tend to mushroom in the center, I don't know the speck by heart but it's a few mm I think. If it's too bad you should mill the head or block.
Old Feb 21, 2013 | 01:40 PM
Mishako129's Avatar
The manual says to do that but only 1/3 a turn at a time or you also risk warping it. He should make sure the engine is stone cold as well.
Old Feb 24, 2013 | 12:37 PM
thanks for the information im doing next weekendthe the gasket is not blown just started leaking i wanted to fix it before it gets worse
Old Feb 24, 2013 | 12:40 PM
https://honda-tech.com/forums/showthread.php?t=2335661
how do i set the timing to its proper position
Old Feb 24, 2013 | 08:18 PM
JamesB1985's Avatar
To remove the cylinder head you are going to have to remove the timing belt first. The smart thing to do would be to position the crankshaft at No. 1 cylinder Top Dead Center before you do anything. After you place your new gasket on the camshaft and crankshaft should still be at TDC (top dead center).
You will be able to tell by looking at the timing marks on the camshaft pulley and the crank pulley. I'm not exactly sure which engine you are working on but you will see the timing marks.
JamesB1985
Mar 5, 2013 06:58 AM
metalmulisha87
Jun 29, 2010 10:43 AM
Defcon2030
Aug 20, 2007 07:11 AM
Lewcis
Jun 24, 2004 11:02 PM
