Turn signal started blinking fast
Old Feb 20, 2013 | 10:34 AM
76 camaro car's Avatar
Default Turn signal started blinking fast
On my 94 accord the left turn signal has started blinking very fast. The right signal blinks just like it always has. I thought maybe a bulb was burned out but checked this morning and all bulbs are blinking. What could be causing this?
Old Feb 20, 2013 | 11:07 AM
jdowen2's Avatar
Default Re: Turn signal started blinking fast
Flasher unit could be flakey.
Old Feb 21, 2013 | 11:46 AM
Must be the flasher, Its getting faster and faster. Almost like a strobe light on the left side now.
Old Feb 21, 2013 | 12:02 PM
codeblaster's Avatar
If not a bulb out, it would have to be a flasher, but I would check the wiring diagram to see if there is another bulb that could have gone out in between.
Old Feb 22, 2013 | 11:55 PM
SyKoTC's Avatar
check the ground pack under the hood, make sure it has a good contact to the chasis. I had similar issue on my 91 CB7
Posted from Honda-tech.com App for Android
Old Feb 24, 2013 | 07:15 AM
poorman212's Avatar
The "flasher" is part of the ICU in the fuse box, I ask everyone to think of how many ICU's have been replaced on a 5th gen because one side blinks faster than the other.
For the left/drivers front lights, G301 is a common ground for the front side marker and the front turn signal lights.
I've been wrong before and will be again...but you would be the first person I know of that has to replace the ICU because one side blinks faster than the other.
Please let us know what it turns out to be.
Old Feb 25, 2013 | 01:13 AM
After rechecking I found that a bulb was out. I swear that the first time I checked it was blinking. After replacing the bulb it was normal again.Thanks for the replies.
Old Feb 25, 2013 | 04:54 AM
GOTRICE12's Avatar
That happened on my 96 honda accord. i just un pluged it and put it back in then it worked just fine
Old Feb 25, 2013 | 03:11 PM
poorman212's Avatar
Good to hear....I've been there before. What I do now is wait until it is dark outside to look for things like this as I'm getting too old and seeing lights when the sun is shinning is getting harder for me
Mister_1
Honda Civic (2006 - 2015)
Jun 5, 2018 05:36 PM
jacreech777
Lighting
Aug 5, 2016 02:27 PM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
civiccoupe94
Oct 14, 2007 05:27 AM
acura1masco
Acura TL, RL & ZDX
Jun 7, 2007 08:32 PM
