custom Turbo for 98 b18 Integra
Hello,
I was thinking about building a custom turbo for my 98 b18 Integra.
Facts and Info:
b18 auto with 29,000 miles, Skunk2 manafold, Venom 400 (remove if turbo is installed).
The following is what I plan on using to build my custom turbo:
t-25 turbo , custom made manifold or rev-hard, stock internals, spark plugs.
dsm BOV, intercooler from eclipse or from semi.
Not sure on what type of boost controller to use?
This is what a want to car to run
low 14's at 6 or 7psi the car is also an everyday driver.
Any input would be helpful
thanks.
Facts and Info:
thanks.
A T25 at that low boost level will not give you much of a power increase at all (not that your auto tranny will withstand much regardless).
I would look into either the GReddy 18G kit or a DRAG/Revhard kit. They come complete with everything you'll need and it's not a tough install.
Good luck.
Good luck.
hmm I would recommend a t3 with mabye turbine size of .63 or less.... t25 probably isen't gonna get you much with low boost...
Your auto will hold power up to 210 at the flywheel or like 160-170whp pretty easily, I'm pushing 189whp and 167lbs right now but my tranny is starting to show signs of slippage, this was only after getting tuned and gaining 25whp and 15lbs more from before tuning....
99V-unit
Feb 28, 2012 09:00 PM
2fastcivic
Jun 18, 2004 05:48 PM
