How long can tires sit for before 'going bad' ?
Old Oct 21, 2002 | 12:16 PM
X2BOARD's Avatar
Default How long can tires sit for before 'going bad' ?
I have a friend that will give me some steelies that have been sitting in his garage (not on a car) for like 3 years... the tires are just about brand new, but will the tires be in good condition (granted no dry rot) after sitting that long ?
X2
Old Oct 21, 2002 | 12:25 PM
brcivic411's Avatar
Default Re: How long can tires sit for before 'going bad' ? (X2BOARD)
how were the tires stored?
Old Oct 21, 2002 | 12:30 PM
X2BOARD's Avatar
Default Re: How long can tires sit for before 'going bad' ? (brcivic411)
On the stock rim on the side, stacked.
Old Oct 21, 2002 | 03:32 PM
performula's Avatar
I had a Corvette that sat outside for two years and the tires held up pretty well. Mich. Pilot XGTZ or somethin like that.
Old Oct 22, 2002 | 10:36 AM
X2BOARD's Avatar
Default Re: How long can tires sit for before 'going bad' ? (performula)
I just want to make sure I don't get any surprises at 80 on the highway... like a 'new' tire popping for no good reason...
X2
Old Oct 22, 2002 | 10:42 AM
Big Phat R's Avatar
3 year old tires are pushing it. You would probably find the rubber very hard and the handling characteristics very different from a new car.
I wouldn't buy them if I was you.
Old Oct 22, 2002 | 10:46 AM
X2BOARD's Avatar
Default Re: How long can tires sit for before 'going bad' ? (Big Phat R)
I'd prolly pick up the things cheap.... I want the steelies and the tires will just be there until I can afford some performance rubber... it'll be for a daily driver for now... $100 for all sound fair ?
Old Oct 22, 2002 | 11:45 AM
Crazydave's Avatar
look for cracks.. and make sure the tire is still "soft" it' should be hard..
store your tires in a cool dark spot away from heat, light, and magnetic fields, preffereably off the rim.. or on the rim with no PSI
Old Oct 22, 2002 | 09:05 PM
X2BOARD's Avatar
Default Re: How long can tires sit for before 'going bad' ? (Crazydave)
?? Are you crazy !?!? LOL....
X2
Old Oct 23, 2002 | 02:39 PM
ayacht's Avatar
The tires your friend has are fine if they where stored inside and not exposed to the sun or weather. The oils used to make the rubber normally require high demand (driving/plying) and quite a bit of weathering to go bad. When on a car they can last years and they are usually exposed to harsh weather conditions and also subject to serious flexing under normal driving conditions. Don't underestimate the engineering that goes into the build of even a cheap tire. If the tire was made in Mexico then you might possible have a problem. The Mexican rubber is developed with the least amount and cheapest of oils, at least in the old days when the VW Beetle was popular. Large inventories of tires at places like Sears have longer life span in the warehouse than three years. They can't turnover every tire size in the place, some being specialty tires and such. So, get yourself a good deal. Also, as stated by one other member, "check for cracks," not only directly, but flex the rubber as much as possible and see if any cracks appear. I doubt you'll find any if they were new (never used) and stored indoors. It isn't like metal, where what you don't see can still contain problems. Thats my 0.02, and I worked in the industry at one time.
vtek9
Aug 11, 2010 06:27 AM
chansaephanh
Mar 29, 2007 01:31 PM
walsh22
Mar 14, 2007 01:08 PM
94civicx
Jun 17, 2002 02:43 PM
Striker
Jan 2, 2002 04:20 PM
