Two Holsets(hx40 and WH1e)
One is a regular 8 blade WH1e(early version of the hx40) the other is a super 40. here are the specs i could find(taken from d-series.org)
both could use a rebuild which i can do, that will change the price though. would like 250 plus shipping for the 8 blade and 350 plus shipping for the super 40. rebuild kits are 50 bucks plus my time in doing the rebuild, will give a price to those interested in that route. will require a deposit to do this as im not buying the kit and sitting on it because someone changed their mind.
The 8blade hx40 has a 58mm inducer and flows about the same as a 60-1 (around 60lb/min) with ALOT better high boost efficiency and spool speed. It is the most common hx40 out there. The small bep housing with the hx40 turbine wheel is plenty to reach the full potential of the 60lb/min 8blade hx40 compressor. 20+ psi by 4100rpms with 272s.
The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing.
bump upon further inspection both impellers are chewed up, a new 6 blade is around 30 bucks on ebay everything else looks fine
the turbos are also on ebay
40
http://www.ebay.com/itm/Holset-HX40-...782f3a&vxp=mtr
WH1E
http://www.ebay.com/itm/Holset-HX40-...783423&vxp=mtr
40
WH1E
