1986 CRX w/ swap not starting???
Old Feb 18, 2013 | 03:35 PM
zduncan1's Avatar
Default 1986 CRX w/ swap not starting???
1986 CRX with a blacktop swap (D16A1) that will not start. I am getting fuel and spark. I have a hasport swap wiring harness, everything is wired to there directions. I'm almost positive the timing is on, at least on the timing belt side, And when I check the distributor side it was TDC. What else can I check? Also tried to start on starting fluid. Still will not start. Any suggestions?
Old Feb 18, 2013 | 03:48 PM
zduncan1's Avatar
Default Re: 1986 CRX w/ swap not starting???
Oh and the crankshaft sensor/cylinder position sensor moves when its turning over.. like wiggles back and forth.
jdmwannabee
Oct 16, 2009 07:49 PM
nieldcrx
Jun 3, 2009 07:06 AM
caster troy si
Sep 8, 2004 12:49 PM
TOFU.man
May 30, 2004 10:54 PM
[626]95-GSR
Feb 14, 2002 06:11 PM
