Transmission & Drivetrain Gearboxes, Differentials, Clutches
94 Accord Wagon H22A w/M2Y4 trans: What axles should I use?
Old Feb 17, 2013 | 05:39 PM
Logan Williams's Avatar
Default 94 Accord Wagon H22A w/M2Y4 trans: What axles should I use?
Hello. I have a 94 Accord Wagon with a JDM H22A swap bolted to a M2Y4 5 speed tranny. My question is what axles should I be running on my setup? I've read that either the Accord or Prelude will work, but I'm curious which people have had better results or more problems with.
I recently took it in to have both front wheel hub assemblies replaced and tie rod ends. The guy told me that he didn't think I had the proper axles under there and felt that is what probably wore out my wheel bearing. (By the way, one of the old wheel bearings fell apart into four pieces when they removed it.)
I bought the car with the swap already done and I'm looking to correct everything and fix it up. No idea what axles are currently being used.
Any thoughts?
BBallz24
Jan 10, 2008 05:10 PM
conesmasher
Sep 3, 2004 12:35 PM
Showoff
Oct 12, 2003 05:39 PM
JdmCIVIC853
Feb 4, 2003 07:36 PM
