Can Any1 in Maryland or surrounding area degree my cams!!!!!
I'm running a b20 vtec with pro3 cams and I'm looking for someone with the skills to degree them in, I have the money just not the experience. Thank you very much please bump if view. 443 467 4649
Holy crap dude stage pro3's are massive! I hope you have the $ for race gas, b/c those need above 12:1 c/r just to "idle"- more like rat-a-tat-tat, rat-a-tat-tat...good luck
That is false. I had Pro3's in my b20v dd and it idle's like stock. As long its tuned and degreed in properly with the correct internals he will be fine
I've watched my friend at Speedfactory degree in my cams and honestly after seeing the neccessary steps, for a cam that big i wouldn't chance it if you don't know what your doing. Just trying to save you time and money
Alot of people will give you different answers, you'll always hear mine be the same.. Run .030(minimal) on v2v and for p2v, its going to depend on you and what you feel safe with there's alot of variations you can run.. people run as little as 0.050, others .120..which is alot lol.
If you know your clearances, drop them in on the drop in settings and move them accordly on the dyno, keeping in mind your chart you should be making.. Keep in mind on the pro series, 99% of the time, the exhaust cam is always more advanced in the intake..
I've always recommended degreeing cams in, in some cases its just not able to happen, due to experince or money issues. Alot of guys use the drop in settings and are fine, IF they know their v2v and p2v.
checking your clearances is MUCH more important than degreeing. if you know your clearances you will know exactly which settings are safe to try on the dyno. theres no point in degreeing the cams w/o checking clearances for two reasons. the first being you may not have enough clearance to run them on the degreed settings. the other being the degreed settings don't always make the best power on the dyno.
check your clearances then dial them in on the dyno. if you want the clearances checked and cams degreed pm me, im in Arnold MD its between Annapolis and bmore.
Post a dyno result I also have a 85x89 Lsvtec 13.5:1 on e85
I'm in for your results, also running a pro3
I'm hopin to have a stock idle once degreed & tuned.... Hopefully
I have Supertech h1000dr springs tho so those might be a little noisy
I'm also shooting for 250+
