Keyless Entry ????
Old Feb 16, 2013 | 12:37 PM
peter-sykes's Avatar
Default Keyless Entry ????
Hi all,
A bit of a dilemma here. My 2000 model Acord V6 Coupe didn't come with a keyless keyfob. I bought reon one from EBAY (THe seller had sold loads of these things for various cars with 100% positive feedback). I downloaded some instructions of the net about "coding it to the car" but I can't get it to swork.
I have checked. and the car has the keyless module fitted (down behind and to the left of the ashtray).
So I guess I'm doing something wrong ????? or the instructions on the internet are nonsense ????
Any help here would be greatly appreciated.
Thanks
Peter
Old Feb 16, 2013 | 12:58 PM
jdowen2's Avatar
Default Re: Keyless Entry ????
Transmitters for the 1998-99 Accord and the 2000-02 Accord look exactly alike, however; they are not interchangeable. 1998-99 transmitter works the doors of a 2000-03 Accord, but it does not open the trunk.
Programming the Transmitter
? Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all of the transmitters once you are in the programming mode.
? You must complete steps 1-6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
1. Turn the ignition switch to ON (II).
2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
Triston1228
Jul 1, 2019 02:49 PM
KmgtypeR
Nov 10, 2016 04:27 PM
rajub
Acura TSX
Feb 19, 2014 05:41 AM
Grooveher
Apr 17, 2007 11:34 AM
