Found white goo under my oil cap.
Old Feb 15, 2013 | 07:40 PM
NZXTInerTia's Avatar
Default Found white goo under my oil cap.
While I was replacing my plenum and TB gasket today (trying to find this never fixed surging idle issue) I checked my oil catch can and found a TON of white goop, then I checked my oil cap. Sure enough it has water in the system... This is recent, could my catch can be causing some sort of water build up? Its a custom catch can, I made a thread for it awhile back. Or is my head gasket shot? I really, really hope its not my head gasket because I refuse to pay to have it done when I can do it myself. I have also now removed my catch can for simplicity's sake, and replaced the oil cap with a spare I had laying around to see if it comes back. I have a KS Tuned balancer shaft delete, and a variable pulley in mind so if the head gasket is bad its not the END of the world, just looking for a more refined answer.
Ideas?
Old Feb 16, 2013 | 12:05 AM
holmesnmanny's Avatar
Default Re: Found white goo under my oil cap.
What does your oil level look like. I suppose that could be sloth from having too much oil.
Old Feb 16, 2013 | 04:03 AM
Deksinjo's Avatar
Maybe PCV ?
Are you loosing coolant ?
Old Feb 16, 2013 | 11:47 AM
I don't have any noticable coolant loss, and my PCV is brand new. I also think my oil level is correct, shoot it was directly in between full and low last time I checked it.
Old Feb 16, 2013 | 12:18 PM
Deksinjo's Avatar
Definitely the humidity but how?
Catchcan is suppose to do job... try to test is coolant system leaking with something like this http://www.harborfreight.com/radiato...kit-69258.html
Old Feb 16, 2013 | 12:26 PM
shiftdrift's Avatar
it happens to a lot of cars, it's just moisture.
Old Feb 16, 2013 | 12:29 PM
peter-sykes's Avatar
Condensation maybe???? Not sure where you are...... But in cold weather that can happen. Head Gasket???? ........ If you aren't losing coolant, a couple of other things you might check before jumping into that one ..........
Is there any trace of oil in the coolant (Try tasting it. It should be sweet and not oily)
Is the any pressure build up in the ccooling system.???? Drive the car up to normal running temp. Then let it stand for a couple of hours or so and release the pressure cap. There should be no residual pressure there.
Hope this helps a bit.
Peter
Old Feb 16, 2013 | 12:53 PM
I live in Minnesota, the last few days the temperature has fluctuated from 37 farenheit to 5 farenheit in a matter of two-three days. Not to mention getting warm, then cold from driving it. I have no residual pressure from the cooling system after being cool to the touch (couple of hours). I would like to invest in a compression tester and a radiator testing setup, even if neithere are wrong with my car I would still like to have them as an open resource. I also found moisture in my plenum when I replaced my gasket last night, if that matters.
I have a 94 EX coupe with an F22B1 but that is irrelevant to the question being asked
Old Feb 16, 2013 | 01:41 PM
electron blueSi's Avatar
Noticed this on my wife's car the other day before doing an oil change. As long as the oil is still good you shouldn't have a problem. But make sure the oil isn't brown from water mixture.
Old Feb 16, 2013 | 05:53 PM
When I checked the oil it was a perfect dark brown color. Not dirty, nor was it too light. I think I'll just keep an eye on it, considering the oil wasn't changed all that long ago.
I see you're from Minot AFB, I was born there. My Dad was active duty Airforce back then. Sweet!
Old Feb 17, 2013 | 01:09 AM
Next step is to do a compression test.
JdmJah
16
Feb 19, 2013 06:42 PM
DRoylflush
11
Apr 10, 2011 02:11 PM
ericstambaugh07
Jun 25, 2007 09:08 AM
vtec.dc2
Aug 15, 2003 06:33 PM
G3gsr
May 20, 2003 06:17 PM
