crx or integra hubs?
when i swapped in my b16 i had to swap out my std hubs. I am not sure if the hubs i put in are from a crx or an integra. My stock caliper did bolt up and i replaced the rotors with ones from a crx si. Does this mean that I FOR SURE have crx hubs (and not teg ones)?
if the crx brakes worked, then you definitely have crx hubs. i put on integra knuckles and rear trailing arms on my crx, the front brakes are much bigger, and the calipers have some big brackets to hold them to the hub, very different from the crx stuff.
