ABS light
I'm new to driving my manual and if I stall, the ABS light comes on. Till then it stays off. It doesn't alter the driving though. Curious as to what I should do about the light coming on or is it normal?
Uh-oh mine does what I described to you. Houston, we have a problem... a lot of people bypass the abs system instead of replacing module. That's what I'm doing when mine starts going bad. I admit I dunno that much about abs so hopefully someone else points you in the right direction. I know dirty fluid will wreak havoc on entire braking system, especially abs module and calipers. Did you replace a wheel bearing or axle lately? The sensors are on each wheel make sure they're not dirty either or cable to/from sensors can get damaged also.
The car actually doesn't have any driving/breaking problems though. I recently bought the car so I'm unsure if the previous owner did any work prior to the purchase. It's really odd. The light comes on but I feel no difference with breaking.
How dirty is fluid? I would try bleeding entire breaking system including abs module if fluid is dark. There's a bleeder on side of abs module, make sure to check fluid level FREQUENTLY when bleeding, you don't want air in any part of system. Take a good look @ sensors/cable to them. Clean sensors w/brake clean and rag if needed
MM&Y of car would help.
Scan for ABS codes.
I agree with S2BumpsticksGSR replace the brake fluid, because it is ABS, I would have a shop do it, flush/replace/bleed.
Old brake fluid is bad on brake systems, very bad for ABS brake systems, if you do not know for sure the fluid has been replaced within the last 3 years, take it to a shop and have it done. 94
Scan for ABS codes.
