FL [FS/FT] 600whp Turbo integra|Foward Facing Setup|Fully Built|Sleeved| L@@K!!
Old Feb 14, 2013 | 11:48 AM
95dc2teg's Avatar
Default [FS/FT] 675whp Turbo integra|Foward Facing Setup|Fully Built|Sleeved| L@@K!!
This is my 1995 Integra GSR. I want 10.5k obo or trade
NO AC (Nothing under the dash or in engine bay), NO PS, NO ABS (converted to non abs).
*car will have plastic race seats and no rear seats. comes with gold drag dr16 and not the blades as pictured. Also has carbon fiber hood with hood pins. Still have the black hood in pictures that will go with it.
Darton sleeved b18c1 bored to 84mm w/ copper O-rings
CP 9.0:1 comp pistons
Eagle H-beam rods
OEM Honda oil pump
OEM Honda water pump
ARP rod bolts
Balanced and blueprinted b18c1 crank
ARP head studs
ARP main bolts
Golden Eagle (honda oem) 84mm head gasket
Ferrea valves (stock size)
Supertech valve springs and titanium retainers
Honda oem valve stem seals
Stock GSR cams Skunk2 cam gears
Precision 6266
JFAB custom 18x12x4 Intercooler
Hondata COP setup
NGK Iridium Spark Plugs
JFAB forward facing turbo manifold
3 inch v-band down pipe
DUAL precision 46mm wastegates
BBK Single Stage intake manifold
BBK 70mm throttle body
Golden Eagle pro-series fuel rail
Golden Eagle Thermal Intake Manifold gasket
Precision 1000cc Injectors
Aeromotive FPR w/ fittings
FULL BLOWN Dual Walbro 255
AEM Uego wideband
Autometer Boost Gauge
Autometer oil pressure gauge
Autometer Gauge pod
Half Dual Core civic radiator
SPAL 13" 1710cfm Slim Fan (i love this thing)
Innovative Race Mounts
Avid Torque Mounts
TIAL Bov
Vented block and valve cover
B&R fittings custom catch tank
GSR Tranny w/Type-R LSD (grind 3rd a bit)
Action Dual Finger pressure plate w/6puk sprung disc
ACT Prolite 9lb flywheel
Hondata s300 with boost control
Skunk2 Coilover with KYB AGE shocks in front
SKunk2 Coilover Drag Launch Kit In rear
Golden Eagle speed holes
4 point roll cage welded into car.
Car was tuned by John Vega @ Phearable.net. Making 450whp @ 17lbs on 93oct and 676whp @ 32psi on C16. Car runs amazing and has perfect compression across the board. I have this motor setup for almost 5 years this coming March, the turbo, manifold, dumptube setup is new as of January 2013.
Best time the car has run so far is a 10.4@147mph on 24.5" slicks
PICS: (gsr blades are no longer on car)
Couple Vids of the Car:
- video a friend made of my car
- Against a friends C6 vette
- agaist a friend skyline, i missed second.
- same race against skyline, outside view
- against a friends 600whp H22 teg.
- inside view on 19lbs pump gas 10.7s @133-135mph
This car is no joke. It was built right, and built to go fast, which is exactly what it does. if interested please message me and i will get back to you as soon as possible.
Old Feb 14, 2013 | 11:58 AM
JumpMan92's Avatar
Default Re: [FS/FT] 600whp Turbo integra|Foward Facing Setup|Fully Built|Sleeved| L@@K!!
Bump and vouch for ant. This is a nice car
Old Feb 15, 2013 | 09:21 PM
95dc2teg's Avatar
Thanks ttt
Old Feb 16, 2013 | 02:16 AM
Discosteak's Avatar
OMFG I want
Old Feb 16, 2013 | 12:10 PM
95dc2teg's Avatar
Thanks for the bump man. Definitely is a fun car to drive!
Old Feb 16, 2013 | 12:17 PM
carbon fiber coupe's Avatar
looks nice a nice build. low 10s no cage?
Old Feb 16, 2013 | 12:19 PM
Discosteak's Avatar
sent you a pm
Old Feb 16, 2013 | 12:51 PM
luvmihatch's Avatar
Nice car man. With a little head work this will see the 9 second bracket. Good build.
Old Feb 16, 2013 | 01:39 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
my sentiments exactly..
Old Feb 16, 2013 | 05:36 PM
Laojoeturbo's Avatar
This thing pulls!
Old Feb 17, 2013 | 12:54 AM
Discosteak's Avatar
very interested pm me back
Old Feb 17, 2013 | 09:25 AM
mn6107's Avatar
Nice
Old Feb 17, 2013 | 11:32 AM
95dc2teg's Avatar
Yes, low 10s, no cage. A cage however is in the works. Interior is currently gutted to get one welded in. Interior will be back after cage is in place.
Old Feb 17, 2013 | 11:34 AM
95dc2teg's Avatar
With new pair of slicks (mine are pretty old, hence the amount of spinning) and 5 more psi I feel I can make a 9.99 pass out of her.
Old Feb 18, 2013 | 09:47 AM
95dc2teg's Avatar
Ttt
Old Feb 18, 2013 | 09:47 PM
95dc2teg's Avatar
Bump
Old Feb 19, 2013 | 05:14 AM
95dc2teg's Avatar
Added more pictures
Old Feb 19, 2013 | 06:04 AM
Discosteak's Avatar
edit nvm
Old Feb 19, 2013 | 06:08 AM
95dc2teg's Avatar
Front bumper
Old Feb 19, 2013 | 07:48 AM
Discosteak's Avatar
Originally Posted by 95dc2teg
Front bumper
no i see that now, I didn't realize the pictures you added were older.
Sent you another pm also
Old Feb 19, 2013 | 05:59 PM
95dc2teg's Avatar
Ya I just wanted to post some pictures of it other than track photos lol
Old Feb 20, 2013 | 05:50 AM
555's Avatar
555
Trades? I have a Vette LT1 v8 swapped Porsche 944 and a 400hp V12 Mercedes W140.
Old Feb 23, 2013 | 03:05 PM
95dc2teg's Avatar
Porsche perks my interest....
Old Feb 24, 2013 | 04:01 AM
555's Avatar
555
How far are you from panama city?
Old Feb 24, 2013 | 12:30 PM
pollito1320's Avatar
i have a very clean 2004 Honda S2000 lmk
