Suspension & Brakes Theory, alignment, spring rates....
Ground Control Perches
Old Feb 14, 2013 | 07:21 AM
DohcSolz's Avatar
Default Ground Control Perches
Ok so ive looked around, and everything i find is 2-5 year old bumped threads with outdated information. I have a 96 civic and I have the Koni Yellow/GC combo. Only problem is all my perches are shot. 2 are seized and the other 2 dont lock at all. I cannot find replacement perches anywhere, and ground control isnt open yet. But i seen these, and maybe figured they are along the same lines. Anybody have a clue if hese would work, as they are for a miata, so most likely not. At the same time they are adjustable so what do you all think?
http://www.good-win-racing.com/Mazda...1068--BAR.html
Old Feb 14, 2013 | 08:17 AM
civexspeedy's Avatar
Default Re: Ground Control Perches
You want to make sure the perch is the right diameter for your sleeves. They make sleeves in different sizes for different cars depending on the diameter of the shock body. I can only assume the the ones for a Miata would not fit ones made for civics/integral. Your best bet is calling Ground Control to see what you can do.
Old Feb 14, 2013 | 10:24 AM
DohcSolz's Avatar
Got it taken care of thanks man!
Old Feb 17, 2013 | 02:15 AM
Fnix's Avatar
So you got replacements?
Old Feb 17, 2013 | 11:12 AM
DohcSolz's Avatar
Yes i called Ground control and they sent me perches and sleeves for 125!
JHall250
52
Jun 14, 2018 07:23 AM
exquiisite_101
Mar 17, 2011 02:51 PM
official-ef8
Aug 31, 2008 01:55 AM
Daniel_san
Aug 17, 2004 12:26 PM
gregor
Feb 24, 2004 11:36 AM
