STARTING ISSUE THAT JUST HAPPENED AN HOUR AGO!!
ok so i have a b18b1 turbo EG hatch. dyno tuned at 350hp 296 tq. i havnt driven the car anywhere due to my license being suspended but the car is still started every single day.
so i wake up to start my car and she turns on with no problem. i let her warm up im jammin out to music an then i decided to put more music onto my usb. i go inside upload more music go back out i start the car back up and im jammin out and all of a sudden the car shuts off. so i was like oh wtf. so i try to turn it back on an it cranks over an all but it doesnt want to turn on. i let it sit for a bit and i try again an its still cranking an not turning on. (i have a half tank of gas btw) so i tried one last time and i heard a very weird strange noise. im not sure if it was crankling or grinding or if it was me buggin out. i didnt want to try cranking it again just incase of something happening so i let the car be and i go inside for a while. i go back out to TRY ONE MORE TIME TO SEE WHATS UP an NOW the car wont even crank over. it just makes a noise as if my air is blowing at fullblast when it wasnt even on...
what is the problem. the prev owner told me to unplug computer and check fuses an check main fuel relay. WHAT IS GOING ON HERE PEOPLE!!!!! i cant check compression because it wont crank now!!!
Have you even checked for the common causes of no start?
Does it have spark?
Does it have fuel? Do you here the fuel pump prime when key is turned to "on" position?
Did the timing belt snap?
Did you do check the things the po told you to do?
Battery is good? Terminals clean and on tight?
Good grounds?
From what you described doing a compression test will not doing anything for you as far as starting the car and why it wont run. Has nothing to do with your problem.
Does it have spark?
Good grounds?
Does it have spark?
Good grounds?
Does it have spark?
Good grounds?
doing everything now
It doesnt sound like the battery, does the car still get power without it cranked? (do the cabin lights come on)
It sounds like the alternator to me. You should check the belt or remove the alternator and take it to autozone they should be able to test it free.
Barely any wouldnt make it seize, especially not driving the car and it just idleing once a day.
Stick to checking the most common things first before getting off track
If you loved me, you'd all sell me your magic cards to me today
Does it have spark?
Good grounds?
Does it have spark?
Good grounds?
here same questions but I would advise printing this out and checking it off
same questions but in flowchart form
http://www.ifitjams.com/starting.htm
why would the car just RANDOMLY shut off like that.. it was running. i shut off. i go inside. i go an start the car again and its idling and running fine an it just shuts off
The starting problem is more than likely directly related to why it cut off on it's own. If you aren't going to follow the advice given to you, why did you even bother asking for help in the first place?
Does it have spark?
Good grounds?
Does it have spark?
Good grounds?
bro everything has been checked an is good... do you think id still be ****** sittin here askin for help?
Then why can you NOT answer any of the questions put to you. And just saying everything was checked doesn't mean you checked it correctly.
Can the attitude please.
