Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Trickle Charging Through Cigarette Lighter
Old Feb 14, 2013 | 04:51 AM
brooklyndodger's Avatar
Default Trickle Charging Through Cigarette Lighter
Guys,
I just acquired several foldable solar panels that were originally meant to charge an Iridium Satellite phone. I am hoping to repurpose them and use one to trickle charge my car battery while I am away in Afghanistan. Is it possible to trickle charge the battery through the cigarette lighter of a 2001Honda Civic? I know you can trickle charge a car through the cigarette lighter on any car that keeps the circuit connected when the key is not in the ignition and not in the "On" position. If I were back in the states I would test by taking the key out of the ignition and testing to see if the cigarette lighter still worked. Any ideas guys? Thanks.
Old Feb 16, 2013 | 07:34 PM
Nitrous1024's Avatar
Default Re: Trickle Charging Through Cigarette Lighter
This will not work.
You are better off connecting the solar panel directly to the battery.
I've been down this road before.
Old Feb 17, 2013 | 11:23 AM
K24_Y61P's Avatar
Why are you so concerned about having the battery trickle charging when you are away? How long do you plan on being gone, that could be a lot of not needed charging? Why not disconnect the battery before you leave?
Old Oct 18, 2013 | 02:41 AM
MarcoHodges's Avatar
Guys,
I just acquired several foldable solar panel that were originally meant to charge an Iridium Satellite phone. I am hoping to repurpose them and use one to trickle charge my car battery while I am away in Afghanistan. Is it possible to trickle charge the battery through the cigarette lighter of a 2001Honda Civic? I know you can trickle charge a car through the cigarette lighter on any car that keeps the circuit connected when the key is not in the ignition and not in the "On" position. If I were back in the states I would test by taking the key out of the ignition and testing to see if the cigarette lighter still worked. Any ideas guys?
Thanks.
I don't think these panels will work..But I still hope for best and can you share your experience? Waiting for reply thanks in advance
Old Oct 19, 2013 | 08:59 AM
dr_spock's Avatar
I don't think it'll work on the Civic since power to the lighter goes off when ignition switch is set to OFF. Which means it is disconnected from the battery.
EJ8Squad919
Nov 18, 2014 06:15 PM
bpr0422
Audio / Security / Video
Mar 3, 2008 04:51 AM
sanjiyan69
Honda Motorcycles
11
Jun 21, 2007 05:39 PM
dingusjt
Feb 5, 2003 12:53 PM
