Lose of power
Old Feb 13, 2013 | 11:59 PM
Michaelcooney12's Avatar
Default Lose of power
Ok once again whats up.everybody I.have a 94 accord with f22b1 with 95k. I drove my budies accord and mine just doesnt feel.astrong. I did new sparkpligs and new oil.and new.filter and new battery I also am missing my bottom.o2 sensor and I have a cracked header how much power am I lossing due.to this .. Its also a vtec and does not go.past 4800 rpms.vtec cracks at 3500 rpm is.that correct any ideas or help.would be.great also got.a compression.test and.all good only number 1 and 3 pistons.are.off by 5 psi any help.woild.be very help.full thank.you.
Old Feb 16, 2013 | 05:31 AM
poorman212's Avatar
Default Re: Lose of power
Don't take this the wrong way but why not fix what is broken before getting into "other issues"?
Any stored codes?
Why not replace the dist cap and rotor if they are due as well.
Old Feb 16, 2013 | 11:20 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by Michaelcooney12
Ok once again whats up.everybody I.have a 94 accord with f22b1 with 95k. I also am missing my bottom.o2 sensor and I have a cracked header how much power am I lossing due.to this.
Fix the header, and reinstall the O2. The car will run remarkably better. Make sure your CEL light works when you turn the car to ON it should light up. If no CEL fix it, that is the only way you will know what codes possible issues drivetrain has.
Old Feb 19, 2013 | 11:14 AM
K cool thnxs guys and ill do that
Ufretin
Jun 8, 2011 01:04 PM
ashv3524
Mar 27, 2005 07:36 AM
rival12
Apr 5, 2004 01:07 PM
