Honda CR-V & Element 2WD & 4WD Element & CR-V
Any issues with slamming a awd 1st gen
Old Feb 13, 2013 | 10:01 PM
1up_Andy's Avatar
Default Any issues with slamming a awd 1st gen
So i have a first gen (98) automatic awd crv and i want to slam it, is there any issues that i will run into? Also i am currently running a staggered setup 17x8/ 17x9 +35 all around wth 215/45/17 tires, any issues with running staggered wheels on a awd?
Old Feb 13, 2013 | 10:31 PM
NZ-DB8R's Avatar
Default Re: Any issues with slamming a awd 1st gen
Have a search PLENTY of info about this as there are quite a few slammed CR-V
Old Feb 14, 2013 | 03:36 AM
LDForget's Avatar
Depends what you consider slamming. I had to cut out all of my inner fender and bash in my frame rails just to steer.
Old Feb 14, 2013 | 04:53 AM
1up_Andy's Avatar
I did serarch, i know about modding the fenders and all that, im asking about any issues with the awd system. I see tons of slammed CRVs but cant tell if they are awd or fwd ones
Old Feb 14, 2013 | 06:21 AM
LDForget's Avatar
Mine was awd until I removed it. Awd system is fine
Old Feb 14, 2013 | 12:09 PM
1up_Andy's Avatar
Was it hard to remove? I want to make mine just fwd since it will never go offroad or see snow anyway.
Old Feb 14, 2013 | 01:53 PM
FeedBack159's Avatar
10 Year Member
ive done it. no problem at all with the awd works fine.
Old Feb 14, 2013 | 01:57 PM
LDForget's Avatar
remove driveshaft
remove differential
remove axles, but leave the stubs in the wheel hubs. they help keep the wheel bearing from seperating.
Old Feb 14, 2013 | 06:08 PM
1up_Andy's Avatar
remove driveshaft
remove differential
Keep the awd trans in or do i have to swap in a FWD trans?
Old Feb 14, 2013 | 09:48 PM
LDForget's Avatar
You can keep the awd trans. Won't hurt anything.
Old Feb 15, 2013 | 05:02 AM
1up_Andy's Avatar
Awesome!! Thanks man
Old Feb 17, 2013 | 11:24 AM
jdm_bones's Avatar
Sorry to thread jack, but in a similar situation, I have a 4wd crv 5 speed, and just installed a set of wheel that have off set, FRONT WHEELS: 7.5 x 17 with 32 Offset with 215/45R17 87W tire and
REAR WHEELS : 8.5 x 17 with 42 offset on 235/45R17 94W tire, my question is will it mess up my rear diff, because of the different size? also will have to install spacers in the rear wheel is to close to the upper control arm.
jdmWONG
Jul 29, 2011 03:40 AM
shutta
Mar 11, 2007 05:10 PM
budget
Jul 25, 2006 08:26 AM
caliprelude3087
Apr 24, 2005 12:59 AM
