Identify year of USDM Type R motor block
I was planning on buying an Itr block no head and was trying to figure out how to tell the year from the serial number code stamped underneath the b18c5 stamp. Or is the vin# the only way of knowing?
What year is your ITR and what is your serial number (stamped underneath b18c5)
this is going off memory, but there should be casting numbers around the block tranny/head. Like a circular stamp/cast that'll say something like 96 or 97 etc...
Hours and hours of searching and I've found it..most other threads go nowhere I know alot of people are wondering the answer to this question because engines before 96 do not have vins. Also I guess Honda can trace the block back to a vin# if you call them.
Thanks for the response but that was just the picture I had to go with and he lived 20 miles from me and wasnt sure on the year. I did end up buying it. Its a 2000
SO because type R uses GSR block then that makes this block a 2000. I checked the vin that is on the block and it matches. Ys005440 I also have a 94 gsr block that is starts with a 1 so I believe this information is correct.
Samer
11 Dec 2004, 09:52:34
Your motor is a 1991 Motor.
If you look at the engine model number and then the Hm number the first number tells you the year of your motor.
i.e. in this case the b18a1 was first in production in 1990 hence the 1xxxxxx and in 1991 it would be 2xxxxxx. So a 94 GSR motor would be b18c1 HM 1xxxxxx and a 99 would be b18c1 HM 6xxxxxx.
Hope this clarifies things
irev210
Jan 22, 2010 06:08 PM
