91 ef zc swap
So I've been doing some searching online an it feels like every other site says a different thing so if I could have some help it would be nice
So I just picked up this beat up 91 ef off this old lady she had told me it had been sitting an that she was going to donate it after talking for a while I bought it off her for $200 got a battery an some carb cleaner an got it started took it home an parked it the next day I start cleaning it an an realize its a zc motor an not a d16 I Kno vary little to nothing on d series or the zc motor but what I would like to Kno is how do I get parts for it so I can give it a tune up cuz from what I have been reading the zc is a Jdm motor any info would really help thanks
Here's a start...
info: http://www.jdmcars.com/tech/admin/zc_engine_info.pdf
part list: http://www.thezcr.com/forums/showthread.php?t=12262 (see attachment)
A lot of the parts from an 89 1.6L integra will work. Timing belt is off a 2.0 89 DOHC prelude motor. Timing belt tensioner, water pump is from a 95 civic 1.6L. You pretty much use the same tranny that you have now.
I have this motor, everything swaps from the original SI motor d16a6.
the difference is the cams are slightly more aggressive on the ZC but otherwise is the same.
the 89 integra was a d16a1? im pretty sure is the code, a dohc d16 motor that is almost its own series as very little is interchangeable from it to other motors, it shares parts with only the other dohc d series and dohc zc none of which are usdm motors. also the integra dohc d16 WILL NOT fit into a 88-2000 Honda. the motor mount comes in front of the timing belt making it rare to see these motors in a Honda other than a custom motor mount...
the dohc zc is much the same as a d16a8 or d16a9
sohc non vtec is a d16a6
sohc vtec is a d16z6
if you ever need to go to a parts store or look up online parts say you have a 91 civic si 1.6 and you will be fine.
douglaslovin
Jul 27, 2008 12:44 PM
