setting base idle
Old Feb 12, 2013 | 06:25 PM
wasp9166's Avatar
Default setting base idle
the label under hood says , 1500 +/- 500
i've read with the iacv unplugged it should be 625
i planned on setting it with iacv plugged in and all things on, fan , lights, defroster, radio to 1500 as i notice a drop in idle when all those things are on
and 1500 seems a big diff from 625..................so whats the correct way?
Old Feb 13, 2013 | 06:46 AM
AlexK47's Avatar
Default Re: setting base idle
Page from shop manual is located here:
http://crxcommunity.com/viewtopic.php?f=4&t=10686
1500 is definitely too high.
Old Feb 13, 2013 | 08:44 AM
g.r.crx's Avatar
base idle is 500 +/-50 with iacv unplugged.
Old Feb 13, 2013 | 10:03 AM
wasp9166's Avatar
mmmmm, why the f does the hood decal say 1500?
and that page is for hf or si
i have the dx d15b1, same setup?
Old Feb 13, 2013 | 10:06 AM
wasp9166's Avatar
ooops, my mistake , didn't scrape enuff dirt,lol
says 750 +- 50 with everything off
for some reason farther down it has fast idle 1500 +- 500
so that 750 is for iacv unplugged then, and everything off??????
cuz if i'm reading that page from manual correctly, it has you check it is 750 with iacv plugged in and all things on, steps 8 and 9
so why wouldn't ya just do that from the get go?
Old Feb 13, 2013 | 10:16 AM
AlexK47's Avatar
No idea why the hood says that. Maybe a typo on the label?
I'm 99% sure it's the same for a d15b1. You should download the shop manual from http://www.spoonertuner.com just to be sure. I'm too lazy to do it.
Old Feb 13, 2013 | 10:21 AM
AlexK47's Avatar
Ah, makes sense with the dirt.
When you turn on the lights, blower, etc., the idle does dip a little, but maybe it changes more/less depending on where the base idle is with everything off. Best just to follow the service manual.
Old Feb 13, 2013 | 10:37 AM
wasp9166's Avatar
yeah, i have a helms, doesn't lay it out as procedure wise like that does so ty
just stumps me as the end result is the same as doing it with everything on and iacv untouched
was just curious what everyone else does
Old Feb 13, 2013 | 01:16 PM
g.r.crx's Avatar
500 unplugged and it goes up to 7-750 after you reset ecu and plug it back in.
Old Feb 14, 2013 | 10:45 AM
Former User's Avatar
What car and engine? Post clear pictures of the hood label.
Old Feb 14, 2013 | 06:12 PM
grog's Avatar
It sounds like you have an charging sysyem issue not an idle issue. If an increased electrical load is causing your idle to drop the ELD could be at fault, although I wouldn't worry much unless its stalling out. its fairly normal for it to fluctuate for a second or 2, but it should go right back to normal.
So whats the reason for wanting to set the idle? It seems like you'd be better served by fixing the underlying issue.
Old Feb 15, 2013 | 04:22 PM
wasp9166's Avatar
91 civic dx d15b1
wasp9166's Avatar
new dizzy, figured may as well look into idle, it doesn't fluctuate or anything, no stalling
but i have noticed elec switches and the like need replacing at 215k
what's the eld?
Old Feb 15, 2013 | 04:27 PM
grog's Avatar
If you dont have an issue with your idle you should probably just leave it alone.
The ELD or "electric load detector" is built into the under hood fuse box. It is in charge of adjusting the idle speed to account for changing electrical loads.
Old Feb 15, 2013 | 04:30 PM
Actually, the ELD is just an energy saving device to increase gas mileage by turning down voltage output by the alternator when it is not needed.
Old Feb 15, 2013 | 04:32 PM
91 civic dx d15b1
Old Feb 16, 2013 | 04:01 AM
wasp9166's Avatar
ty ron, but i have an ecu fuse in box under hood, do i pull that or the hazard?
Old Feb 16, 2013 | 06:11 AM
Remove the hazard fuse for 3 minutes or so to reset the ECU.
Old Feb 16, 2013 | 06:26 AM
wasp9166's Avatar
ok, ty
will post what i find
i'm using this
http://www.automotivetoolsonline.com...r_p_10700.html
also, i dunno grog, i have an 04 bmw 330i and i notice a drop in heater fan rpm when lights are turned on
Old Feb 16, 2013 | 06:27 AM
Nice
Old Feb 17, 2013 | 09:29 AM
wasp9166's Avatar
well, i noticed no change in idle whatsoever when disc iacv
i also could not get the idle down to 625 , the motor would stall first
so, i reconnected and was able to set it at 810 with everything on
any reason for this?
clean iacv or just replace?
like i said, idle doesn't search or anything like that, it's steady, just seems like iacv isn't doing jack
Old Feb 18, 2013 | 09:43 AM
wasp9166's Avatar
bueller? anyone?
Old Feb 19, 2013 | 03:39 AM
wasp9166's Avatar
no one knows if this is normal operation of iacv?
Old Feb 19, 2013 | 11:57 AM
AlexK47's Avatar
Was the car warmed up? If the car is warmed up and the base idle is set to a reasonable value, I think disconnecting the IACV should not really do anything.
If the car is cold and the IACV isn't doing anything, there's definitely something wrong with it.
Old Feb 19, 2013 | 12:29 PM
wasp9166's Avatar
yes, says to warm up car before doing procedure, also couldn't get idle down to 625 like it says, was waaay too low, motor shaking etc
it's at 810 with everything on, i'm just going to clean iacv and set it that way
not sure why you unplug iacv and then go on to checking with it plugged back in further in procedure
810 seems high as when everything is turned off the idle comes up a bit, but
that's what it says i guess
