Suspension & Brakes Theory, alignment, spring rates....
rear disc conversion on 99 civic ex
Old Feb 12, 2013 | 05:33 PM
francoreyes90's Avatar
Default rear disc conversion on 99 civic ex
Hey everybody im sure this topic has been discussed some time but I am wanting to do a rear disc conversion. I need help knowing from what type of vehicle I can remove them from it is a four lug type. Also I know about the propotioning valve but im wondering if it is better to switch the master cylinder. please help!
Old Feb 12, 2013 | 05:37 PM
Redis_323's Avatar
Default Re: rear disc conversion on 99 civic ex
if you find out plz do share.
Old Feb 12, 2013 | 06:10 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
When you google it, you will figure it out because as you stated it has been discussed many many many times!!!
Should check out the stick at the top of this section...
So do you need some one to install them or do you think you can handle it?
Old Feb 12, 2013 | 07:52 PM
98civdx's Avatar
Master Detailer
92-00 Civic.
94-01 Integra (except ITR)
Or buy the scarebird thing and keep your stock trailing arms.
You'll want to get a 99-00 SI prop valve. leave the MC alone.
Old Feb 12, 2013 | 10:07 PM
Id like to install them myself but this is my first time so it would be of much help if I had someone help me out ive asked around they said its not hard to do but dont want to mess anything up
Old Feb 13, 2013 | 06:46 PM
98civdx's Avatar
Master Detailer
Install is easy... Hardest part would be swapping the prop valve.
Old Mar 23, 2013 | 03:49 PM
Ryu-Oh's Avatar
I'm about to do the same conversion with mine.
Old Mar 26, 2013 | 06:15 AM
Aurel's Avatar
I made a rear brake swap with Civic MB6 parts.
It's full bolt-on like DC2 parts, discs, pads and calipers have the same size as 98' DC2, but hub is 1cm larger on each side than DC2 8)
Old Mar 26, 2013 | 10:56 AM
BCGARAGE_ED7's Avatar
Originally Posted by 98civdx
92-00 Civic.
I believe you're supposed to use the SI ebrake cables as well.
Posted from Honda-tech.com App for Android
Old Mar 26, 2013 | 07:48 PM
98civdx's Avatar
Master Detailer
Indeed, drum/disk E brake lines are totally different.
I didn't put that because I assumed he already knew that.
HONDABOI666
Mar 8, 2011 06:44 PM
modifyORdie
Jan 12, 2006 03:17 PM
modifyORdie
Suspension & Brakes
Jan 12, 2006 08:55 AM
