HELP B20 swap
Old Feb 12, 2013 | 03:49 PM
Vamikeymike's Avatar
Default HELP B20 swap
I hAve a 2000 Honda civic ex I am putting a b20 swap in it what Ecu can I use to run it that is a obd2b Ecu please help thank you
Old Feb 12, 2013 | 04:03 PM
Default Re: HELP B20 swap
Isn't Acura still obd2a in 99?
Old Feb 12, 2013 | 04:13 PM
94EG8's Avatar
Seagull Management
Yep, '00 - '01 are OBD2B, but have an immobilizer. A '98 - '01 5 speed CR-V ECU actually works fine. OBD2B and no immobilizer. The engine harness works as well.
Old Feb 12, 2013 | 04:39 PM
Is that obd2b though
Old Feb 12, 2013 | 05:19 PM
94EG8's Avatar
Seagull Management
Yes it is. The USDM B20Z ('99 - '01) uses a small plug distributor as well that plugs into the stock '99 - '00 Civic harness. (can also be used on LS swaps in the same cars)
Old Feb 12, 2013 | 05:46 PM
So on eBay what should I type in the search
Old Feb 12, 2013 | 06:09 PM
94EG8's Avatar
Seagull Management
You want a PHK ECU, like so:
http://www.ebay.ca/itm/00-01-Honda-C...-/221115842475
I'm not sure what the part numbers for the '98 and '99 are.
'00 - '01 is 37820-PHK-A03
Old Feb 12, 2013 | 06:15 PM
Thanks for the help
Old Feb 12, 2013 | 06:19 PM
HondaPartsHero's Avatar
Technical Hero
Sorry had a brain fart. You can also use 96-99 P75 with a jumper harness if you can't find the crv ecu and still be obd2 compliant.
Hays419
Mar 7, 2016 12:43 AM
blackccoupe
May 11, 2014 10:05 AM
eric p
Feb 7, 2009 04:25 PM
fishboy
Nov 3, 2008 03:42 PM
NAmodified
Dec 5, 2006 05:32 PM
