Injector wiring
Old Feb 12, 2013 | 01:16 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Injector wiring
I need confirmation on voltage read out.
When measuring for voltage, I get 12v on the black wires on each injector and no voltage on signal wire. I believe that the ECU controls injectors via shorting ground, is that correct?
Old Feb 12, 2013 | 01:40 PM
Default Re: Injector wiring
Follow up question, what should reading should there be between the terminals of the injector plugs in igntion on position? I am getting 12 volts on injector 1 & 3 across the pins and nothing on injector 2 & 4.
Old Feb 12, 2013 | 04:21 PM
crx_si-r's Avatar
Sounds like an mpfi conversion?
Old Feb 12, 2013 | 04:30 PM
4drEF's Avatar
Keyboard Humorist
Correct. ECU sends ground pulses.
Take the distributor off and rotate it by hand.
You might see a pulse jump by... or you might not.
Correct tool is noid lights.
Old Feb 12, 2013 | 05:45 PM
thank you for the info.
not a MPFI conversion, ITB install. ended up being two injectors clogged.
chrysanderson
14
Nov 7, 2010 09:08 PM
codyw
Apr 29, 2010 02:23 PM
98vtec
12
Feb 12, 2008 03:30 PM
Hondatec38
Mar 4, 2003 08:57 PM
