Painting Engine Bay with NO AIR!
Old Feb 12, 2013 | 11:13 AM
TeggieeTuner's Avatar
Default Painting Engine Bay with NO AIR!
Alright guys, this isnt the first time ive used this method but I figured I would share it with everyone because it was my only option this time around.
Things you need:
Tape
stripped engine bay
sandpaper
scotchbrite pads
primer
wax and grease remover
single stage urethane paint
Preval spray gun( Oreilly auto parts)
1000-1500 grit/buffer ( if you chose to wetsand/buff)
Im sure I forgot some stuff but here are the steps I did.
*Stripped the engine bay of almost everything.
* sanded down with 200ish grit
*went over with scotchbrite pad
*primed
*wiped down with wax and grease remover
*painted ( 2 coats )
* wetsanded and buffed the areas I could reach 2 days later
The sprayer:
Before:
After:
Old Apr 20, 2013 | 09:24 AM
Default Re: Painting Engine Bay with NO AIR!
Finished:
Old Apr 20, 2013 | 11:16 AM
slow_sihatch's Avatar
Damn looks good
Old Apr 20, 2013 | 11:26 AM
Thanks, need better quality photos...
Old Apr 20, 2013 | 10:05 PM
What kind of paint did you use?
Old Apr 20, 2013 | 10:13 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
what kind of clamp did you use to connect your AN line to your fuel line, not putting you down but that doesnt look right
Old Apr 21, 2013 | 05:09 AM
I flared the end of the fuel line a bit, then used to small *** clamps that barely fit to get it retarded tight.
Old Apr 21, 2013 | 05:10 AM
single stage urethane from Napa auto parts
Old Apr 21, 2013 | 08:50 AM
Ok I think I'm going to have to try this
Old Apr 21, 2013 | 03:23 PM
wELLpLAYED77's Avatar
That Preval spray gun does a pretty decent job of course the prep work has a lot to do with it as well... good job! I will have to try my hand at that as well.
Old Apr 21, 2013 | 04:49 PM
Thanks guys
Old Apr 21, 2013 | 04:51 PM
TypeRfit's Avatar
RESIDENT
Great idea you gave everyone
Old Apr 22, 2013 | 05:50 PM
JDM94TEG's Avatar
Yes great idea, will have to try it also.
sl0wDA9
Paint and Body
Dec 22, 2009 11:51 AM
Pabs626
Paint and Body
Jun 11, 2008 07:16 AM
welfarepc
Paint and Body
Oct 30, 2007 09:37 AM
crxpwr1
Jun 17, 2006 08:05 AM
EyelessCRX
17
Jul 9, 2004 06:37 AM
